[Ovmsdev] can log vfs crashes
Thu Oct 1 02:01:33 HKT 2020
Derek,
that's the typical watchdog reset.
I have no vehicle needing to use two buses, but even with high volume
traffic on CAN1, I don't see high CPU usages. With my 10ms interval CAN
feed and a running crtd log, I get ~ 4-5% additional CPU load on core 1.
Nowhere near a watchdog trigger reason.
Maybe there is some flaw in the MCP driver or in your poll reply handling?
What CPU usages do you see normally vs. with logging enabled? Do you see
abnormal spikes in some task?
(Except Duktape, that needs some CPU once per minute for the garbage
collection…)
Am 30.09.20 um 08:43 schrieb Derek Caudwell:
> Hi Michael,
> When the vehicle is not set to poll and only receiving can1 messages I
> managed to obtain a 10Mb file - logging a variety of signals some with
> 10ms timing without any issues. However, when polling and can1/can2
> are operating and I try to log the same signals I get the following
> crash trace. I would suspect the underlying cause of the crashing
> relates to both buses being active as opposed to the polling but that
> may not be the case.
> Last crash: abort() was called on core 0 Backtrace: 0x4008e627
> 0x4008e8c1 0x400e7060 0x40083f6a Event: ticker.1 at esp32wifi 0 secs WDT
> tasks: IDLE1|OVMS DukTape
> 0x4008e627 is in invoke_abort
> (/mnt/c/linux/ovms/esp-idf/components/esp32/panic.c:156).
> 151     #endif
> 152         while (1) {
> 153             if (esp_cpu_in_ocd_debug_mode()) {
> 154                 __asm__ ("break 0,0");
> 155             }
> 156             *((int *) 0) = 0;
> 157         }
> 158     }
> 159
> 160     void abort()
> 0x4008e8c1 is in abort
> (/mnt/c/linux/ovms/esp-idf/components/esp32/panic.c:171).
> 166          * don't overwrite that.
> 167          */
> 168         if (esp_reset_reason_get_hint() == ESP_RST_UNKNOWN) {
> 169             esp_reset_reason_set_hint(ESP_RST_PANIC);
> 170         }
> 171         invoke_abort();
> 172     }
> 173
> 174
> 175     static const char *edesc[] = {
> 0x400e7060 is in task_wdt_isr
> (/mnt/c/linux/ovms/esp-idf/components/esp32/task_wdt.c:174).
> 169         esp_task_wdt_isr_user_handler();
> 170         if (twdt_config->panic){     //Trigger Panic if configured
> to do so
> 171             ESP_EARLY_LOGE(TAG, "Aborting.");
> 172             portEXIT_CRITICAL_ISR(&twdt_spinlock);
> 173             esp_reset_reason_set_hint(ESP_RST_TASK_WDT);
> 174             abort();
> 175         }
> 176
> 177         portEXIT_CRITICAL_ISR(&twdt_spinlock);
> 178     }
> 0x40083f6a is at
> /mnt/c/linux/ovms/esp-idf/components/freertos/xtensa_vectors.S:1154.
> 1149        wsr     a0, PS
> 1150        rsync
> 1151
> 1152        /* OK to call C code at this point, dispatch user ISRs */
> 1153
> 1154        dispatch_c_isr 1 XCHAL_INTLEVEL1_MASK
> 1155
> 1156        /* Done handling interrupts, transfer control to OS */
> 1157        call0   XT_RTOS_INT_EXIT                /* does not return
> directly here */
> 1158
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200930/587378a5/attachment-0001.htm>
