[Ovmsdev] PSRAM bugfix: next round
    Chris van der Meijden
    chris at arachnon.de
    Sun Nov  8 20:10:35 HKT 2020
Hi Michael,
it worked all flawlessly for me (Linux64).
I'm now on
3.2.015-152-ge81e84d7-dirty/ota_1/main (build idf v3.3.4-845-gd59ed8bba
Nov  8 2020 12:55:44)
Thanx!
Chris
Am Sonntag, den 08.11.2020, 12:22 +0100 schrieb Michael Balzer:
>     Everyone,
>     the announced bug fix for the regression in toolchain
>     1.22.0-96-g2852398 has been released for esp-idf v3.3.
>     I've merged the latest updates to esp-idf release 3.3.4 into our
>     fork and added the new options to our default build
> configuration.
>     This includes some additional PSRAM related fixes.
>     The toolchain download links in the docs have not yet been
> updated.
>     Use these links to download the new toolchain:
>       Linux 64 bit:
> https://dl.espressif.com/dl/xtensa-esp32-elf-linux64-1.22.0-97-gc752a
> d5-5.2.0.tar.gz
>       MacOS:
> https://dl.espressif.com/dl/xtensa-esp32-elf-macos-1.22.0-97-gc752ad5
> -5.2.0.tar.gz
>       Windows 64 bit:
> https://dl.espressif.com/dl/xtensa-esp32-elf-win32-1.22.0-97-gc752ad5
> -5.2.0.zip
>     See
> https://github.com/espressif/esp-idf/commit/81da2bae2aa3e15a1793d40bb
> 9648620f8cd2555
>     for other architectures.
>     Simply replace your existing toolchain installation by unpacking
> the
>     archive. Test your toolchain installation by checking
>      xtensa-esp32-elf-gcc --version.
>     To update your esp-idf clone:
>       cd $IDF_PATH
>       git pull
>       git submodule update --recursive
>     Replace your sdkconfig by the default one or set all new config
>     options to their defaults. I recommend doing a full rebuild of
> the
>     OVMS firmware (i.e. make clean ; make).
>     You should then get firmware version 3.2.015-150-
> gf6121ddd/factory/edge
>       (build idf v3.3.4-845-gd59ed8bba Nov  8 2020 11:50:31) or
>     higher.
>     Regards,
>     Michael
>     Am 31.07.20 um 22:10 schrieb Michael
>       Balzer:
> >       But according to the latest comment to the PSRAM issue
> > (https://github.com/espressif/esp-idf/issues/2892#issuecomment-6670
> > 99130)
> > the fix in the official release had a regression. In some cases,
> > the bug
> > will occur again. The report issue #5423 had the effect of this
> > freezing
> > the LwIP task, which would create the WDT / event issue for us as
> > well.
> > I'd rather apply the coming toolchain fix release first.
> > I'll keep you informed about the toolchain progress.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201108/7ef8706b/attachment-0002.htm>
