[Ovmsdev] Hacking TPMS
    Tue May 19 15:58:03 HKT 2020
Jaunius,
The board will look like this (pcb layout for the first few samples):
I’ve tried to make it as generic as possible.
SW1 is a four position switch
#0 - no connection (with test point that can inject custom voltage if required)
#1 - USB 5v. Bus is powered with 5v from the USB (useful for bench testing)
#2 - LDO 5v. Bus is powered with 5v using a LDO to regulate down vehicle 12v power
#3 - 12v. Bus is powered from vehicle 12v
S1 is a on/off switch. When on, it adds a diode+resistor to the K-Line (which is required by some cars for K-line tools being master).
Test points everywhere, to help debugging
For roadster, SW1 is #2 and S1 is off.
It is exposed to the ESP32 as an async port, at 3.3v levels. But the transceiver handles the bus at 5v or 12v. It works with K-line, and should also work with LIN, if required. EGPIO8 is used to enabled/disable the transceiver (normally disabled).
P.S. Circuit schematic attached.
> On 18 May 2020, at 9:14 PM, Jaunius Kapkan <jaunius at gmx.com> wrote:
> Very nice.
> I wonder can this be optimized to support other metrics? Like using GPS coordinates from CAN instead of the GPS module itself for cars that have it available?
> Jaunius Kapkan [Sent from cellphone]
>> On 2020-05-11, at 03:57, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>> I’ve been spending the last month or so hacking away at TPMS. This has been an ongoing project for the Tesla Roadster that is finally coming to fruition.
>> About a year or so ago, we already made changes to:
>> Modify the Tesla Roadster cable to connect the k-line pin on the diagnostic connector through to the DB9 connector on OVMS. We labelled this cable ‘OVT1’.
>> Modify the OVMS module to connect that k-line pin to GEP7.
>> I’m now working on an optional expansion board that will include a little TJA1027T transceiver and map it to EXP1 and EXP2 (for async comms) and EGPIO8 (for enable/disable) on the ESP32 and MAX. This board will include a jumpered option for K-line master (one diode + one resistor), as well as jumpered powered selection (5v from usb, 5v regulated from car 12v, or direct car 12v) for the K-line bus.
>> The hand-soldered prototype, using our breakout boards, works well and the K-line async comms works. The screenshot shows OVMS sending a 19 byte request to the ECU (0x0f 0x04 .... 0xf0) and the ECU responding 19 bytes (0x0f 0x05 ... 0xf0) with the 4 tyre IDs. There is a similar command to re-program the ECU with new IDs.
>> On the firmware side, I am implementing a new vehicle independent ’tpms’ subsystem within OVMS (enabled via configureable option). This will allow sets of tyres to be maintained in the config and read/written to the car's TPMS ECU. The following commands will be available:
>> tpms status - show status of the system
>> tpms list - list tyre id sets in config
>> tpms read <set> - read IDs from tpms ecu and store in config tyre set
>> tpms write <set> - write IDs to toms ecu from config tyre set
>> tpms set <set> {<id>} - config a set of IDs manually
>> tpms delete <set> - delete the specified tyre set
>> The initial version will support Tesla Roadster, but the functionality is there for other vehicles to use if they need it (in particular for standard K-line implementations).
>> Comments/suggestions welcome.
>> +++Attachments+++
>> Bench setup, showing (from left to right):
>> Tesla Roadster TPMS ECU opened up
>> Breakout board (power, k, Lin, and can)
>> OVMS for can decode
>> Usb logic analyser
>> Power supply (12v)
>> K-line analysis tool (9010)
>> Windows laptop running k-line software
>> Mac running logic analyser and terminal to OVMS.
>> <image0.jpeg>
>> Hand-soldered prototyping board
>> <image0.jpeg>
>> Async comms over k-line.
>> <image1.jpeg>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200519/52bbbe7c/attachment.htm>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200519/52bbbe7c/attachment-0002.png>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200519/52bbbe7c/attachment-0001.htm>
Name: K-Line Board.pdf
Type: application/pdf
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200519/52bbbe7c/attachment-0002.pdf>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200519/52bbbe7c/attachment-0002.htm>
