[Ovmsdev] can polling
Tamás Kovács
kommykt at gmail.com
Sat May 2 00:00:44 HKT 2020
i found the problem:
static const OvmsVehicle::poll_pid_t vehicle_mitsubishi_polls[] =
{ 0x761, 0x762, VEHICLE_POLL_TYPE_OBDIIGROUP, *0x02*, { 0, 10,
10 } }, // cac
{ 0, 0, 0, 0, { 0, 0, 0 } }
This (uderlined and bold thext) is in my old code is 0x01 after i chage it
to it, working.
The only thing i get the values from IncomingFrameCan1 (with old code
removed CAN_frame_t frame;.... code )
i can use this momde or use IncomingPollReply to get data? Which is best?
Tamás Kovács <kommykt at gmail.com> ezt írta (időpont: 2020. máj. 1., P,
10:17):
> Can anybody help me understanding can polling?
> I use the following code in 3.0.12 and older version.
> i send every 60s when the car is on a following code:
> CAN_frame_t frame;
> memset(&frame,0,sizeof(frame));
> frame.origin = m_can1;
> frame.FIR.U = 0;
> frame.FIR.B.DLC = 3;
> frame.FIR.B.FF = CAN_frame_std;
> frame.MsgID = 0x761;
> frame.data.u8[0] = 0x02;
> frame.data.u8[1] = 0x21;
> frame.data.u8[2] = 0x01;
> m_can1->Write(&frame);
> At IncomingFrameCan1 i catch the response message at 0x762 and send a flow
> control message (this values from can logging during genuine diagnostic use
> on car)
> if (d[0] == 16)
> // Request CAC...
> CAN_frame_t frame;
> frame.FIR.U = 0;
> frame.data.u8[0] = 0x30;
> frame.data.u8[1] = 0x08;
> frame.data.u8[2] = 0x0A;
> And with this is get some data (CAC)
> But if i use polling with the following values
> { 0x761, 0x762, VEHICLE_POLL_TYPE_OBDIIGROUP, 0x02, { 0, 10,
> 10 } }, // cac
> i get the following in void OvmsVehicleMitsubishi::IncomingPollReply....
> I (178194) v-mitsubishi: 762 TYPE:21 PID:02 7 01 7e 01 7e 01 7f 01 00
> I (178224) v-mitsubishi: 762 TYPE:21 PID:02 7 7e 01 7e 01 7e 01 7e 00
> I (178284) v-mitsubishi: 762 TYPE:21 PID:02 7 01 7e 01 7e 01 7e 01 00
> I (178284) v-mitsubishi: 762 TYPE:21 PID:02 7 7e 01 7e 01 7e 01 7e 00
> I (178314) v-mitsubishi: 762 TYPE:21 PID:02 7 01 7e 01 7e 01 7e 01 00
> I (178344) v-mitsubishi: 762 TYPE:21 PID:02 7 7e 01 7e 01 7e 01 7e 00
> I (178374) v-mitsubishi: 762 TYPE:21 PID:02 7 01 7e 01 7e 01 7e 01 00
> I (178404) v-mitsubishi: 762 TYPE:21 PID:02 7 7e 01 7e 01 7e 01 7e 00
> I (178434) v-mitsubishi: 762 TYPE:21 PID:02 7 01 7e 01 7e 01 7e 01 00
> I (178464) v-mitsubishi: 762 TYPE:21 PID:02 7 7e 01 7e 01 7e 01 7e 00
> I (178494) v-mitsubishi: 762 TYPE:21 PID:02 7 01 7e 01 7e 00 00 00 00
> i run a can logging with this session and i only see the same data
> (incomping poll reply) only the d[0] is changed.
> What do i do wrong?
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200501/7472b82d/attachment.htm>
