[Ovmsdev] can polling
Tamás Kovács kommykt at gmail.com
Fri May 1 16:17:47 HKT 2020
Can anybody help me understanding can polling?
I use the following code in 3.0.12 and older version.
i send every 60s when the car is on a following code:
CAN_frame_t frame;
    memset(&frame,0,sizeof(frame));
    frame.origin = m_can1;
    frame.FIR.U = 0;
    frame.FIR.B.DLC = 3;
    frame.FIR.B.FF = CAN_frame_std;
    frame.MsgID = 0x761;
    frame.data.u8[0] = 0x02;
    frame.data.u8[1] = 0x21;
    frame.data.u8[2] = 0x01;
    m_can1->Write(&frame);
At IncomingFrameCan1 i catch the response message at 0x762 and send a flow
control message (this values from can logging during genuine diagnostic use
on car)
if (d[0] == 16)
        // Request CAC...
        CAN_frame_t frame;
        frame.FIR.U = 0;
        frame.data.u8[0] = 0x30;
        frame.data.u8[1] = 0x08;
        frame.data.u8[2] = 0x0A;
And with this is get some data (CAC)
But if i use polling with the following values
static const OvmsVehicle::poll_pid_t vehicle_mitsubishi_polls[] =
    { 0x761, 0x762, VEHICLE_POLL_TYPE_OBDIIGROUP,  0x02, {       0,  10,
10 } }, // cac
     { 0, 0, 0, 0, { 0, 0, 0 } }
i get the following in void OvmsVehicleMitsubishi::IncomingPollReply....
I (178194) v-mitsubishi: 762 TYPE:21 PID:02 7 01 7e 01 7e 01 7f 01 00
I (178224) v-mitsubishi: 762 TYPE:21 PID:02 7 7e 01 7e 01 7e 01 7e 00
I (178284) v-mitsubishi: 762 TYPE:21 PID:02 7 01 7e 01 7e 01 7e 01 00
I (178284) v-mitsubishi: 762 TYPE:21 PID:02 7 7e 01 7e 01 7e 01 7e 00
I (178314) v-mitsubishi: 762 TYPE:21 PID:02 7 01 7e 01 7e 01 7e 01 00
I (178344) v-mitsubishi: 762 TYPE:21 PID:02 7 7e 01 7e 01 7e 01 7e 00
I (178374) v-mitsubishi: 762 TYPE:21 PID:02 7 01 7e 01 7e 01 7e 01 00
I (178404) v-mitsubishi: 762 TYPE:21 PID:02 7 7e 01 7e 01 7e 01 7e 00
I (178434) v-mitsubishi: 762 TYPE:21 PID:02 7 01 7e 01 7e 01 7e 01 00
I (178464) v-mitsubishi: 762 TYPE:21 PID:02 7 7e 01 7e 01 7e 01 7e 00
I (178494) v-mitsubishi: 762 TYPE:21 PID:02 7 01 7e 01 7e 00 00 00 00
i run a can logging with this session and i only see the same data
(incomping poll reply) only the  d[0] is changed.
What do i do wrong?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200501/e8e7eb68/attachment.html>
