[Ovmsdev] Locations (actions, etc)
Tue May 5 15:01:09 HKT 2020
Mark & Steve,
is "location action" a convenience wrapper for the event script system?
If so, should we leverage it to events in general, i.e. "event action …"?
Am 05.05.20 um 07:13 schrieb Stephen Casner:
> Mark,
> Implementing actions is still on my TODO list, but the location
> command to configure the actions was working.  The "Unrecognized
> command" response indicates that something has broken.  It should
> allow the command and store the requested action, but then show the
> warning "NOTE: Actions are not implemented yet!"  You will see that
> same warning after the output of the "location list" command.
> Part of the work I completed was an enhancement to the command parsing
> to allow lists of keywords following a variable token, like you see
> acc, homelink or notify after <location> in the Usage output.  This
> code was a bit tricky.  I have not paid close attention to recent
> commits to any of the command processing code, so maybe some change
> was made that was incompatible with my enhancement.
> I will investigate.
> On Tue, 5 May 2020, Mark Webb-Johnson wrote:
>> What is the current status of the changes you have been making to the locations
>> system?
>> I have a user asking why:
>>       >location set Likini
>>       >location action enter Likini notiffy entered
>>       >****: location action enter Likini notify entered
>>       Unregconised command
>>       Usage: location action enter <location> acc <profile>
>>       Usage: location action enter <location> homelink 1|2|3
>>       Usage: location action enter <location> notify <text>
>> Was this ever completed?
>> Regards, Mark
