[Ovmsdev] New Plugins Heat Assist & Climate Control Timers
Jaunius Kapkan
jaunius at gmx.com
Thu Mar 12 16:01:32 HKT 2020
Hi Mark,
As the NL code has been optimized for both 2013 and 2016 year models I was waiting for Anko to make the final test. As otherwise it would break the current climate control metrics for the existing 30kwh Leafs.
But if this is not a problem, we can make the pull, as otherwise the code is ready.
Jaunius Kapkan [Sent from cellphone]
> On 2020-03-12, at 04:24, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Looks good.
> Let’s get your firmware changes pulled back in, so this can gain wider usage. Let me know what is needed.
> It would also be interesting to get plugins like this into a central repository, with simple HTTP download and install from our UI.
>> On 11 Mar 2020, at 6:46 AM, Jaunius K. <jaunius at gmx.com> wrote:
>> Hi,
>> Finally had some time to finalize and make the plugins user friendly. I
>> have been using them for all winter (3 months now) so they should be
>> pretty stable by now.
>> You will find read-me and description in my GitHub repository:
>> https://github.com/mjkapkan/OVMS-Plugins
>> Note that as these are one of the first apps I write in JavaScript,
>> there may be some awkward approaches, but in the end they serve the
>> purpose just fine.
>> Jaunius
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200312/6a87da96/attachment.htm>
