[Ovmsdev] New Plugins Heat Assist & Climate Control Timers
Anko Hanse
anko_hanse at hotmail.com
Fri Mar 13 03:01:09 HKT 2020
Hi Jaunius,
Sorry for the delay on my side, just have been a bit too busy in the past couple of weeks.
Go ahead and check in your code if you want. We can always fix bugs later if we find any, but the last code I saw was already pretty stable. Worst case your new code will show a wrong HVAC metric, where the original code would likely have been wrong anyway…
OKidoki,
Anko
Sent: Thursday, 12 March 2020 9:02 pm
To: OVMS Developers <ovmsdev at lists.openvehicles.com>
Subject: Re: [Ovmsdev] New Plugins Heat Assist & Climate Control Timers
Hi Mark,
As the NL code has been optimized for both 2013 and 2016 year models I was waiting for Anko to make the final test. As otherwise it would break the current climate control metrics for the existing 30kwh Leafs.
But if this is not a problem, we can make the pull, as otherwise the code is ready.
Jaunius Kapkan [Sent from cellphone]
On 2020-03-12, at 04:24, Mark Webb-Johnson <mark at webb-johnson.net<mailto:mark at webb-johnson.net>> wrote:
Looks good.
Let’s get your firmware changes pulled back in, so this can gain wider usage. Let me know what is needed.
It would also be interesting to get plugins like this into a central repository, with simple HTTP download and install from our UI.
On 11 Mar 2020, at 6:46 AM, Jaunius K. <jaunius at gmx.com<mailto:jaunius at gmx.com>> wrote:
Hi,
Finally had some time to finalize and make the plugins user friendly. I
have been using them for all winter (3 months now) so they should be
pretty stable by now.
You will find read-me and description in my GitHub repository:
https://github.com/mjkapkan/OVMS-Plugins
Note that as these are one of the first apps I write in JavaScript,
there may be some awkward approaches, but in the end they serve the
purpose just fine.
Jaunius
OvmsDev mailing list
OvmsDev at lists.openvehicles.com<mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200312/a8ab29c8/attachment.html>
