[Ovmsdev] New Plugins Heat Assist & Climate Control Timers
Thu Mar 12 10:23:13 HKT 2020
Looks good.
Let’s get your firmware changes pulled back in, so this can gain wider usage. Let me know what is needed.
It would also be interesting to get plugins like this into a central repository, with simple HTTP download and install from our UI.
> On 11 Mar 2020, at 6:46 AM, Jaunius K. <jaunius at gmx.com> wrote:
> Hi,
> Finally had some time to finalize and make the plugins user friendly. I
> have been using them for all winter (3 months now) so they should be
> pretty stable by now.
> You will find read-me and description in my GitHub repository:
> https://github.com/mjkapkan/OVMS-Plugins
> Note that as these are one of the first apps I write in JavaScript,
> there may be some awkward approaches, but in the end they serve the
> purpose just fine.
> Jaunius
