[Ovmsdev] OVMS Server v3
Mon Mar 9 15:30:57 HKT 2020
> On 9 Mar 2020, at 2:39 PM, Craig Leres <leres at xse.com> wrote:
> On 2020-03-08 23:20, Mark Webb-Johnson wrote:
>> The message 'ovms-server-v3: Tx event server.v2.connecting’ is confusing. It means that ovms-server-v3 is transmitting it’s received event ’server.v2.connecting’ to the MQTT server. The transmitter of the event was presumable server-v2.
> Are you saying it's the V3 server that is failing to connect when I enable TLS for the V2 server?
No, just that the message shown appears confusing and may be why you suspect v3 server is interfering with v2 server.
>> The big issue I see is ‘W (269308) gsm-mux: Frame overflow (2048 bytes)’. That would imply the GSM comms is messed up. Surprised anything works after that.
> Would that caused by poor signal strength? When in the garage my cars usually see anywhere from -97 to -101 dBm.
> Anyway I don't understand why I can't see the cars on my iphone when I enable TLS for the V2 server.
I think most likely some buffer overflow in the modem communications. Which modem version is this with?
