[Ovmsdev] 3.2.013
    Chris van der Meijden
    chris at arachnon.de
    Wed Jun 10 21:42:31 HKT 2020
OK, now this was silly :-)
I just needed to
git push origin master --tags
Chris
Am Mittwoch, den 10.06.2020, 15:39 +0200 schrieb Chris van der Meijden:
> Thanx for your quick response.
> --tags did the trick for the local version when compiling.
> Nevertheless the tags are not pushed back with "git push origin
> master" into my fork on github. There the "releases" and "tags" are
> still on 3.2.010 ...
> I will google that ...
> Am Mittwoch, den 10.06.2020, 21:17 +0800 schrieb Mark Webb-Johnson:
> > You probably need to include —tags as an option on your git fetch.
> > The version is in the tag.
> > Regards, Mark
> > > On 10 Jun 2020, at 8:59 PM, Chris van der Meijden <chris at arachnon
> > > .de> wrote:
> > >   Hi all,
> > > sorry for a perhaps silly question, but I don't understand the
> > > version numbering between master and fork.
> > > I regulary merge the changes from the ovms repository to my fork.
> > > So far so good and I am up to date at the moment. OVMS is now on
> > > release 3.2.013. When I perform a pull request on my fork and do
> > > a "make" on my local machine, I'm still on release 3.2.010. Even
> > > though the code is absolutely up to date.
> > > Could someone give me a hint on how to get the release numbers
> > > synced between the ovms master and my fork?
> > > Thanx in advance.
> > > Greetinx
> > > Chris
> > > Am Mittwoch, den 10.06.2020, 07:40 +0200 schrieb Michael Balzer:
> > > >     Followed.
> > > >     Regards,
> > > >     Michael
> > > >     Am 10.06.20 um 03:28 schrieb Mark
> > > >       Webb-Johnson:
> > > > >       No issues reported, so just released this to MAIN.
> > > > >       Regards, Mark.
> > > > > >             On 5 Jun 2020, at 1:15 PM, Michael Balzer <dext
> > > > > > er at expeedo.de> wrote:
> > > > > >                Followed.
> > > > > >                 Regards,
> > > > > >                 Michael
> > > > > >                 Am 05.06.20 um 07:06
> > > > > > >                   I have release this 3.2.013 to EAP.
> > > > > > >                   Regards, Mark.
> > > > > > > >                         On 31 May 2020, at 5:34 PM,
> > > > > > > > Mark
> > > > > > > >                           Webb-Johnson <mark at webb-johns
> > > > > > > > on.net>
> > > > > > > >                           wrote:
> > > > > > > >                             Getting ready to release
> > > > > > > >                               3.2.013. I’ve tagged it,
> > > > > > > > and built for api.openvehicles.com edge.
> > > > > > > >                             The main changes here are:
> > > > > > > >                                 TPMS subsystem
> > > > > > > > (including
> > > > > > > >                                   Tesla Roadster
> > > > > > > > support with new
> > > > > > > >                                   optional K-line
> > > > > > > > expansion board)
> > > > > > > >                                 Change to config for
> > > > > > > >                                   server.v2
> > > > > > > >                             For #2, I moved the server
> > > > > > > >                               password from
> > > > > > > > server.v2/password to
> > > > > > > >                               password/server.v2, and
> > > > > > > > made the server.v2
> > > > > > > >                               config parameter read-
> > > > > > > > write. That better
> > > > > > > >                               matches how server.v3
> > > > > > > > does it. The change
> > > > > > > >                               is done via a config
> > > > > > > > migration, so should
> > > > > > > >                               be transparent.
> > > > > > > >                             Absent any issues, I plan
> > > > > > > > to
> > > > > > > >                               move to EAP early in the
> > > > > > > > coming week.
> > > > > > > >                             Regards, Mark
> > > > > > > > _______________________________________________
> > > > > > > >                           OvmsDev mailing list
> > > > > > > >                           OvmsDev at lists.openvehicles.co
> > > > > > > > m
> > > > > > > >                           http://lists.openvehicles.com
> > > > > > > > /mailman/listinfo/ovmsdev
> > > > > > > ________
> > > > > > > OvmsDev at lists.openvehicles.com
> > > > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> > > > > > __
> > > > > > o/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200610/2d79702d/attachment.htm>
