[Ovmsdev] 3.2.013
    Wed Jun 10 21:43:10 HKT 2020
Also —tags on the push.
> On 10 Jun 2020, at 9:40 PM, Chris van der Meijden <chris at arachnon.de> wrote:
> Thanx for your quick response.
> --tags did the trick for the local version when compiling. Nevertheless the tags are not pushed back with "git push origin master" into my fork on github. There the "releases" and "tags" are still on 3.2.010 ...
> I will google that ...
> Am Mittwoch, den 10.06.2020, 21:17 +0800 schrieb Mark Webb-Johnson:
>> You probably need to include —tags as an option on your git fetch.
>> The version is in the tag.
>> Regards, Mark
>>>> On 10 Jun 2020, at 8:59 PM, Chris van der Meijden <chris at arachnon.de> wrote:
>>> Hi all,
>>> sorry for a perhaps silly question, but I don't understand the version numbering between master and fork.
>>> I regulary merge the changes from the ovms repository to my fork. So far so good and I am up to date at the moment. OVMS is now on release 3.2.013. When I perform a pull request on my fork and do a "make" on my local machine, I'm still on release 3.2.010. Even though the code is absolutely up to date.
>>> Could someone give me a hint on how to get the release numbers synced between the ovms master and my fork?
>>> Thanx in advance.
>>> Greetinx
>>> Chris
>>> Am Mittwoch, den 10.06.2020, 07:40 +0200 schrieb Michael Balzer:
>>>> Followed.
>>>> Regards,
>>>> Michael
>>>> Am 10.06.20 um 03:28 schrieb Mark Webb-Johnson:
>>>>> No issues reported, so just released this to MAIN.
>>>>> Regards, Mark.
>>>>>> On 5 Jun 2020, at 1:15 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>>>>> Followed.
>>>>>> Regards,
>>>>>> Michael
>>>>>> Am 05.06.20 um 07:06 schrieb Mark Webb-Johnson:
>>>>>>> I have release this 3.2.013 to EAP.
>>>>>>> Regards, Mark.
>>>>>>>> On 31 May 2020, at 5:34 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>>>>>>> Getting ready to release 3.2.013. I’ve tagged it, and built for api.openvehicles.com edge.
>>>>>>>> The main changes here are:
>>>>>>>> TPMS subsystem (including Tesla Roadster support with new optional K-line expansion board)
>>>>>>>> Change to config for server.v2
>>>>>>>> For #2, I moved the server password from server.v2/password to password/server.v2, and made the server.v2 config parameter read-write. That better matches how server.v3 does it. The change is done via a config migration, so should be transparent.
>>>>>>>> Absent any issues, I plan to move to EAP early in the coming week.
>>>>>>>> Regards, Mark
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200610/45309c98/attachment.htm>
