[Ovmsdev] Strange app behavior
    Sébastien Darveau
    sebastien.darveau at synnoetic.com
    Tue Jun  9 20:24:25 HKT 2020
Hi,
I’ve also seen this strange behavior yesterday afternoon. I’m connected on the same server (api.openvehicles.com <http://api.openvehicles.com> ). The car was going out of range of the Wifi and using the modem at that time. It seems stable now.
Sebastien Darveau
On Jun 9, 2020, at 1:48 AM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net> > wrote:
Steve,
I wasn’t aware of this issue, but will look into it. I can’t immediately see the cause, but it should be relatively easy to add a clean-up of the channel structures when the connection starts.
I haven’t restarted the api.openvehicles.com <http://api.openvehicles.com/> server recently.
On 9 Jun 2020, at 1:39 PM, Stephen Casner <casner at acm.org <mailto:casner at acm.org> > wrote:
That sounds plausible.  Since the problem ceased, I wonder if that
implies that the server was restarted.  I'm using Mark's server.
On Mon, 8 Jun 2020, Michael Balzer wrote:
That may have been https://github.com/openvehicles/Open-Vehicle-Server/issues/2
Am 08.06.20 um 19:02 schrieb Stephen Casner:
I'm running 3.2.012.  This morning when I went to check the status
after charging overnight, which had completed, the iPhone app was
behaving in a very strange manner.  I cycled a few times (for as long
as I watched) through three states at an interval on the order of
10-20 seconds:
1. 86%, ideal range 191, no charge connector icon.  Those range and
SOC numbers were correct, but the charge cable was connected.
2. 95%, ideal range 177, charge connector icon shown.
3. 48%, don't recall the range, no charge connector icon.
When I checked the Car screen, it too was cycling among showing no
numbers, showing old gray numbers, and showing some numbers in white.
I don't recall their accuracy.
Now after I finished my morning walk the display appears stable and
correct with 86%, ideal range 190, and charge connector icon shown.
The Car screen shows just old numbers in gray except for the aux
battery voltage.  Sorry I didn't have the presence of mind to grab
screenshots.
OvmsDev mailing list
OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200609/3c1fa813/attachment.htm>
