[Ovmsdev] Strange app behavior
    Tue Jun  9 13:48:57 HKT 2020
Steve,
I wasn’t aware of this issue, but will look into it. I can’t immediately see the cause, but it should be relatively easy to add a clean-up of the channel structures when the connection starts.
I haven’t restarted the api.openvehicles.com <http://api.openvehicles.com/> server recently.
> On 9 Jun 2020, at 1:39 PM, Stephen Casner <casner at acm.org> wrote:
> That sounds plausible.  Since the problem ceased, I wonder if that
> implies that the server was restarted.  I'm using Mark's server.
> On Mon, 8 Jun 2020, Michael Balzer wrote:
>> That may have been https://github.com/openvehicles/Open-Vehicle-Server/issues/2
>> Am 08.06.20 um 19:02 schrieb Stephen Casner:
>>> I'm running 3.2.012.  This morning when I went to check the status
>>> after charging overnight, which had completed, the iPhone app was
>>> behaving in a very strange manner.  I cycled a few times (for as long
>>> as I watched) through three states at an interval on the order of
>>> 10-20 seconds:
>>> 1. 86%, ideal range 191, no charge connector icon.  Those range and
>>> SOC numbers were correct, but the charge cable was connected.
>>> 2. 95%, ideal range 177, charge connector icon shown.
>>> 3. 48%, don't recall the range, no charge connector icon.
>>> When I checked the Car screen, it too was cycling among showing no
>>> numbers, showing old gray numbers, and showing some numbers in white.
>>> I don't recall their accuracy.
>>> Now after I finished my morning walk the display appears stable and
>>> correct with 86%, ideal range 190, and charge connector icon shown.
>>> The Car screen shows just old numbers in gray except for the aux
>>> battery voltage.  Sorry I didn't have the presence of mind to grab
>>> screenshots.
>>>                                                        -- Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200609/1ec0ea5b/attachment.htm>
