[Ovmsdev] VW e-Up read/poll via OBD is working
Fri Jul 31 00:32:50 HKT 2020
"@devmarxx: Is there any doc/guide on how to use this RE Tools?"
Here is a link:
https://docs.openvehicles.com/en/latest/plugin/retools/README.html
Not much I'm afraid, but it can bring you on track ...
Chris
Am Donnerstag, den 30.07.2020, 17:56 +0200 schrieb Soko:
>     @Michael: Yeah, I know. You would have done my 1-day work in 5
>       mins. I know C++ but I don't know the OVMS framework. But its
> like
>       with any project: The issue is not the language, its the
>       framework.
>     Until you have yours you have to settle with me unfortunately ;)
>     My cousin has a working VCDS HEX interface and I have an
>       y-adapter so I can listen with an ELM327 adapter to the
> commands
>       VCDS is sending. Maybe I can find any car status there. Device
> 09
>       is a good hint.
>     But as you said: I have still have to poll this, even if I find a
>       status.
>     I can't say (of course) if there's another CAN bus @ OBD port.
>       All this CAN/OBD/Bus stuff is completely new to me.. ModBus
>       RTU/TCP, MBus etc. I would know ;)
>     So if you can point me in any direction what to try - or what you
>       would do - I happy to dig into it.
>     Soko
>     PS: Any idea when you'll get your Mii?
>     On 30.07.2020 17:14, Michael Balzer
>       wrote:
> >       If only I had my Mii already…
> >       If the OBD port is shielded from the CAN traffic, you need to
> > poll
> >       some device. ECU = Engine Control Unit = device 01.
> >       I would suspect the basic car status info to be available
> > from
> >       device 09 (central electrics), but it seems no PIDs have been
> > RE'd
> >       from there yet. So maybe you need to derive the info from
> > some
> >       other mode/status register.
> >       It's bad needing to continuosly poll to get the live status
> > data.
> >       Is possibly another, unfiltered CAN bus available at the OBD
> > port?
> >       Regards,
> >       Michael
> >       Am 30.07.20 um 16:43 schrieb Soko:
> > >         Ahhh OK, I've found OvmsVehicle::virtual void
> > >           TickerXXX(uint32_t ticker);
> > >           Got it! This was exactly my issue as I didn't know
> > > about any
> > >           function which gets called regularly so I could check
> > >           something like this...
> > >           It's not an ideal situation though: I just can slow
> > > down the
> > >           poll after my fail-counter gets too high as I need to
> > > check
> > >           when the car gets powered again. So all I can do is
> > > polling,
> > >           lets say every 60 secs when the car is off, and
> > > increase it
> > >           once its on. But there is now way around this 60-sec
> > > polling
> > >           if the only thing I can do is poll :(
> > >         Afaik there is only the sharkcow's list below, reverse
> > >           engineered by him from ODBeleven.
> > >         (dev)marxx exlpained to me: There is a gateway between
> > > the
> > >           CAN-Buses and the OBD Connector in all VW-AG vehicles
> > > which
> > >           only replies to polls and also acts as security gateway
> > > if you
> > >           want to write to the buses.
> > >         So I think I cannot really do a can log or use re tool as
> > > the
> > >           OBD interface stays quiet if I'm not polling it...
> > >         And as there is no other vehicle from
> > > VW,Seat,Skoda,Audi,etc.
> > >           in OVMS. So I have no cheat-sheet :(
> > >         Anyhow... I would need to poll one ECU (is this the
> > > correct
> > >           therm?) which doesn't shuts down... or maybe the issue
> > > is the
> > >           OBD-gateway shutting down.
> > >         What do you think?
> > >         Soko
> > >         On 30.07.2020 16:17, Michael Balzer
> > >           wrote:
> > > >           Soko,
> > > >           nice progress :-)
> > > >           If you can't detect vehicle state by listening to
> > > > regular
> > > >           status CAN frames, you can check the time since the
> > > > last poll
> > > >           reply in the per second ticker.
> > > >           As poll replies normally come in fast, you should be
> > > > able to
> > > >           detect a switch-off by a small timeout, say 3
> > > > seconds…
> > > >           probably need to add a counter, as a single poll may
> > > > get lost
> > > >           / ignored.
> > > >           CAN tx errors can be caused by other issues as well,
> > > > so should
> > > >           generally not be interpreted that way.
> > > >           But… are you sure there are no status frames on the
> > > > bus? Have
> > > >           you done a can log or tried the re tool?
> > > >           Regards,
> > > >           Michael
> > > >           Am 30.07.20 um 14:43 schrieb
> > > >             Soko:
> > > > > Hi
> > > > >             guys,
> > > > >             Want to report success on connecting and reading
> > > > > my VW e-Up
> > > > >             via OBD cable using the Poller. As you can see in
> > > > > the
> > > > >             screenshot of the log attached I get an
> > > > >             IncomingPollReply(..) call and an SoC value of
> > > > > 33.333%
> > > > >             Once I turn of the ignition and lock the car
> > > > > though I don't
> > > > >             get any replies no more (line D 793813) and then
> > > > > I get can1
> > > > >             errors... I'm polling with 10 seconds intervall.
> > > > >             I know that this is as it should be... but my
> > > > > issue is: I
> > > > >             don't have any way to know if the ignition is on,
> > > > > the key is
> > > > >             in, the car is running, the car is charging as
> > > > > the PIDs are
> > > > >             not known for such values (afaik by the lists of
> > > > > sharkcow https://www.goingelectric.de/wiki/Liste-der-OBD2-Cod
> > > > > es/).
> > > > >             So what would be the best approach to change the
> > > > > different
> > > > >             polling states? Can I somehow get called (in my
> > > > >             vehicle-class) if an can-error is thrown? Then I
> > > > > would
> > > > >             increase the poll frequency.
> > > > >             Any suggestions?
> > > > >             thanks
> > > > >             Soko
> > > > >             _______________________________________________
> > > > > OvmsDev mailing list
> > > > > OvmsDev at lists.openvehicles.com
> > > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
> > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200730/75ffef96/attachment.htm>
