[Ovmsdev] Wifi setup
Derek Caudwell
d.caudwell at gmail.com
Sun Jul 12 04:33:06 HKT 2020
Thanks for the fix! Switching between my APs (all unique ssids, so not
tested bssid) works on loss of signal or reboot as expected with the
exception that on one running OpenWrt as an extender, so goes back to main
router for Dhcp, it is not getting an IP after the switch/gw/dns.
I will enable verbose logging later and see if provides more detail on what
is happening. Reboot of OpenWrt device is probably a good starting point.
> Date: Sat, 11 Jul 2020 00:15:18 +0300
> From: Jaunius Kapkan <jaunius at gmx.com>
> To: OVMS Developers <ovmsdev at lists.openvehicles.com>
> Subject: Re: [Ovmsdev] Wifi setup
> Message-ID: <75886DAD-F082-4EFC-9509-2A565B1C9121 at gmx.com>
> Content-Type: text/plain; charset="utf-8"
> Really appreciate you guys taking the time to fix this. I also use the
> module in wifi only mode and was constantly getting disconnects. I blamed
> this on the poor wifi connection in the parking spot, but as it turns out
> the problem was far deeper.
> Jaunius Kapkan [Sent from cellphone]
> > On 2020-07-10, at 23:42, Michael Balzer <dexter at expeedo.de> wrote:
> > ? *sigh* Found it? it turned out my main router needed a reboot. I
> assume somehow a faulty ARP cache entry got stuck.
> > https://www.youtube.com/watch?v=nn2FB1P_Mn8
> > So, no fault or bug on the module side.
> > Checking the code once again I nevertheless found one remaining
> potential bug, fix is pushed.
> > Regards,
> > Michael
> > Am 10.07.20 um 20:53 schrieb Michael Balzer:
> >> Sorry for not including the examples. The Edimax does not have a host
> name, it's addressed using the IP, no DNS involved.
> >> Linux host request example working the same way with both the old & new
> version:
> >> HTTP.Request({
> >> url: "http://192.168.2.108/f/test.json",
> >> always: function() { JSON.print(this, false); }
> >> (OK, no output)
> >> D (42703) script: DuktapeHTTPRequest: started '
> http://192.168.2.108/f/test.json'
> >> D (42913) script: DuktapeHTTPRequest: MG_EV_CONNECT err=0/Success
> >> D (42933) script: DuktapeHTTPRequest: MG_EV_HTTP_REPLY status=200
> bodylen=20
> >> D (42943) script: DuktapeHTTPRequest: MG_EV_CLOSE status=200
> >> D (42963) script: DuktapeHTTPRequest: done status=200 bodylen=20 url='
> >> D (42973) script: DuktapeHTTPRequest: calling method 'always' nargs=0
> >> I (43173) script: [eval:3:] {"url":"http://192.168.2.108/f/test.json","always":function
> () { [ecmascript code]
> },"redirectCount":0,"error":"","response":{"statusCode":200,"statusText":"OK","body":"{
> \"das\": \"klappt?\" }","headers":[{"Date":"Fri, 10 Jul 2020 17:03:18
> GMT"},{"Server":"Apache"},{"Last-Modified":"Sun, 29 Dec 2019 11:01:41
> GMT"},{"ETag":"\"14-59ad5a6d190da\""},{"Accept-Ranges":"bytes"},{"Content-Length":"20"},{"Cache-Control":"max-age=0"},{"Expires":"Fri,
> 10 Jul 2020 17:03:18 GMT"},{"Content-Type":"application/json"}]}}
> >> ?vs. Edimax working with the old version:
> >> HTTP.Request({
> >> url: "http://192.168.2.106/",
> >> (OK, no output)
> >> D (533720) script: DuktapeHTTPRequest: started 'http://192.168.2.106/'
> >> D (533920) script: DuktapeHTTPRequest: MG_EV_CONNECT err=104/Connection
> reset by peer
> >> D (533930) script: DuktapeHTTPRequest: MG_EV_CLOSE status=0
> >> D (533950) script: DuktapeHTTPRequest: failed error='Connection reset
> by peer' url='http://192.168.2.106/'
> >> D (533950) script: DuktapeHTTPRequest: calling method 'always' nargs=0
> >> I (533990) script: [eval:3:] {"url":"http://192.168.2.106/","always":function
> () { [ecmascript code] },"redirectCount":0,"error":"Connection reset by
> peer"}
> >> (connection reset = expected result here, as connecting w/o credentials
> to the default port -- to show it's host related)
> >> ?but not with the new version:
> >> (OK, no output)
> >> D (151953) script: DuktapeHTTPRequest: started 'http://192.168.2.106/'
> >> ?18 seconds?
> >> D (170273) script: DuktapeHTTPRequest: MG_EV_CONNECT err=113/Software
> caused connection abort
> >> D (170273) script: DuktapeHTTPRequest: MG_EV_CLOSE status=0
> >> D (170293) script: DuktapeHTTPRequest: failed error='Software caused
> connection abort' url='http://192.168.2.106/'
> >> D (170303) script: DuktapeHTTPRequest: calling method 'always' nargs=0
> >> I (170333) script: [eval:3:] {"url":"http://192.168.2.106/","always":function
> () { [ecmascript code] },"redirectCount":0,"error":"Software caused
> connection abort"}
> >> Regards,
> >> Michael
> >> Am 10.07.20 um 20:03 schrieb David Corrigan:
> >>> Sounds like a DNS issue. I?m really foggy on the details but you can
> probably look this stuff up easily enough. Local stuff is resolved a bit
> differently, it?s something like your home router keeps track of the names
> that get DHCP reservations and append .local so somehow when looking for
> devices the client needs to query that as well as the main DNS IPs given to
> it by the DHCP server. It might be that the same DHCP server automatically
> appends it?s own up IP to the list. There?s a discussion on it here that
> might yield some ideas
> https://superuser.com/questions/591863/how-to-resolve-local-domain-name
> >>> On Fri, Jul 10, 2020 at 12:47 PM Michael Balzer <dexter at expeedo.de>
> wrote:
> >>>> It seems I've found a real issue with the new implementation, I don't
> know how to explain:
> >>>> With the new implementation, mongoose fails to establish a HTTP
> connection to my Edimax smart plug. Just that device, every other host
> works correctly, also with SSL.
> >>>> The mg_connect_http_opt() call fails after 18 seconds with error 113
> "Software caused connection abort" ? which may be a timeout or the LWIP
> error code 113 "No route to host" passed through by mongoose.
> >>>> Same behaviour in both client & apclient mode, fixed & scanning.
> >>>> The Edimax is on the same network as the module (connected to the
> same AP) and perfectly reachable from all other stations (and the build
> before). Netmask and gateway are correct. Also the wifi connect is still
> done by the esp_wifi_connect() call, so there should be no difference??
> >>>> I'm puzzled. Any ideas? Any other hosts that cannot be connected to
> with the new version?
> >>>> To test a host, use this JS snippet in the editor with a URL of a
> small page or non existent file on the host:
> >>>> HTTP.Request({
> >>>> url: "http://?",
> >>>> Regards,
> >>>> Michael
> >>>> Am 10.07.20 um 15:21 schrieb Michael Balzer:
> >>>>> The dhcps log messages aren't new, I've had these all the time
> before, also sometimes repeating for some period.
> >>>>> Also not new are these messages:
> >>>>> I (8771413) wifi: ampdu: ignore deleting tx BA0
> >>>>> I (8774723) wifi: ampdu: ignore deleting tx BA0
> >>>>> I (8784043) wifi: ampdu: ignore deleting tx BA0
> >>>>> I (8787253) wifi: ampdu: ignore deleting tx BA0
> >>>>> I (8793673) wifi: ampdu: ignore deleting tx BA0
> >>>>> I (8797813) wifi: ampdu: ignore deleting tx BA0
> >>>>> They now start consistently after doing a scan from a web client
> connected via the AP. They stop when the client disconnects. Seem to be
> coupled to the websocket somehow. I've found these in my log archives as
> well, no clue about the trigger. No issue other than annoying log spam
> though, everything works normally.
> >>>>> Regards,
> >>>>> Michael
> >>>>> Am 10.07.20 um 14:36 schrieb Mark Webb-Johnson:
> >>>>>> Working for me on my test bench device. I?m building EDGE now.
> >>>>>> Only strange thing so far is I am seeing this message repeatedly in
> apclient mode:
> >>>>>> dhcps: send_nak>>udp_sendto result 0
> >>>>>> Can?t work out the timing, as it seems to be random. I?ll keep
> looking...
> >>>>>> Regards, Mark
> >>>>>>> On 10 Jul 2020, at 7:42 PM, Michael Balzer <dexter at expeedo.de>
> wrote:
> >>>>>>> Everyone,
> >>>>>>> the wifi rework is pushed:
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/5d1f124060326b92f35887878b4d49c8012542dc
> >>>>>>> ?and the new edge build is on my server.
> >>>>>>> This now allows to scan for networks in all modes without
> disruption of a running wifi network.
> >>>>>>> I've used this to also add a network selection dialog to the setup
> wizard & wifi config.
> >>>>>>> The apclient mode can now be started without a client SSID to let
> the module automatically connect to any network configured. The autostart
> config page now allows this setup. The special "scanning client" mode has
> been removed.
> >>>>>>> The wifi manager will still stick to an established connection,
> even if a new network with higher signal strength becomes available. I
> thought about automatically switching networks if the signal gets poor, but
> for now decided against it to avoid frequent network reconfigurations in
> edge cases. If you want the module to explicitly scan for a better network,
> issue "wifi reconnect".
> >>>>>>> Of course this has involved some changes to the wifi manager, so
> please test & report.
> >>>>>>> Regards,
> >>>>>>> Michael
> >>>>>>> Am 10.07.20 um 08:57 schrieb Michael Balzer:
> >>>>>>>> TL;DR: yes, I'm currently also going towards not letting
> esp_wifi_connect() decide which AP to connect to.
> >>>>>>>> More precisely, exactly the first (!) call to esp_wifi_connect()
> after a reboot/power up seems to do a round robin scheme among all
> reachable access points of a network regardless of their signal strength.
> This even applies to the first connect() immediately after a scan.
> >>>>>>>> Example:
> >>>>>>>> D (5034) events: Signal(system.wifi.scan.done)
> >>>>>>>> V (5034) esp32wifi: ScanDone: #01 ssid='WLAN-214677'
> bssid='7c:ff:4d:15:2f:86' chan=11 rssi=-64
> >>>>>>>> V (5034) esp32wifi: ScanDone: #02 ssid='WLAN-214677'
> bssid='94:4a:0c:c3:9e:63' chan=11 rssi=-77
> >>>>>>>> I (5044) esp32wifi: Found SSID WLAN-214677 - trying to connect
> >>>>>>>> I (7564) esp32wifi: STA connected with SSID: WLAN-214677, BSSID:
> 94:4a:0c:c3:9e:63, Channel: 11, Auth: WPA2
> >>>>>>>> The next reboot will connect to 7c:ff (despite unchanged signal
> strengths), the next again to 94:4a and so on. I've only got two access
> points, so I can't test if it's really round-robin, but it's wrong anyway.
> >>>>>>>> On all following reconnects on the running system it will
> correctly pick the 7c:ff AP, also if wifi is stopped & restarted.
> >>>>>>>> This AP switching behaviour also persists powering off the
> module, so the wifi blob seems to do this on purpose and even use some
> persistent storage to implement it. Totally undocumented and I've found no
> way to disable this and no workaround so far.
> >>>>>>>> There may be a fix for this in the current esp-idf wifi blob, but
> I've found no issues on this, and esp-idf commit comments are mostly not
> useful.
> >>>>>>>> Regards,
> >>>>>>>> Michael
> >>>>>>>> Am 10.07.20 um 02:55 schrieb Mark Webb-Johnson:
> >>>>>>>>> FYI:
> >>>>>>>>> I?ve recently done some work with the esphome system (based on
> platformio on top of esp idf), for home automation. They don?t seem to
> trust the ESP libraries identifying the strongest signal (in the case of
> two APs broadcasting the same SSID). They don?t blindly connect to a SSID,
> but instead first do a scan to produce an ordered list and then connect to
> the SSID+AP-MAC-Address of the AP with the strongest signal.
> >>>>>>>>> That approach might help with your other issue (recently raised
> in mantis).
> >>>>>>>>> Regards, Mark.
> >>>>>>>>>> On 10 Jul 2020, at 5:43 AM, Michael Balzer <dexter at expeedo.de>
> wrote:
> >>>>>>>>>> ? Welcome Derek,
> >>>>>>>>>> I've got a rework of the wifi component near done that allows
> to use scanning mode in apclient configuration. I think I can push the
> changes tomorrow & suggest you'll be my beta tester ;-)
> >>>>>>>>>> Regards,
> >>>>>>>>>> Michael
> >>>>>>>>>> Am 09.07.20 um 20:50 schrieb Derek Caudwell:
> >>>>>>>>>>> Hi devs,
> >>>>>>>>>>> I recently received the ovms hardware and have been trying to
> setup the unit so I can solely use the wifi AP+client. In NZ 3G is soon to
> be sunset and for my needs I don't really need a connection when I'm
> driving (and want to make sure everything is behaving nicely on the can bus
> before I do).
> >>>>>>>>>>> I realise AP+client brings it limitations however hopefully
> some of these can be worked around as I want to be able to use the
> dashboard/plugins as well as the mobile app. I am new to C/ESP32
> programming and the code base so I thought it best to ask a few questions
> before I begin tinkering with it.
> >>>>>>>>>>> Ideally I want the unit on loss of connection to an AP to try
> and find another AP that has been set in the wifi config and connect. The
> parts I am not too sure are as follows:
> >>>>>>>>>>> - on boot the code uses the default wifi ssid, if the default
> is not available how does the code try and switch to one of the other saved
> APs?
> >>>>>>>>>>> - can multiple APs be saved to the wifi config memory and
> handled by ESP32? or do they need to be retrieved from ovms config, wifi
> client details set, try connect and enumerated through?
> >>>>>>>>>>> - I assume EventTimer10 is the logical place to add extra
> code if required to enumerate through APs and try to connect? similar to
> EventScanWifiDone when in SClient mode
> >>>>>>>>>>> - What is the reason scanning mode is unavailable for
> AP+client mode in auto init, from the ESP32 documentation it appeared to be
> usable still but with limitations?
> >>>>>>>>>>> Thanks in advance for any pointers and background.
> >>>>>>>>>>> Cheers Derek
> >>>>>>>>>>> _______________________________________________
> >>>>>>>>>>> OvmsDev mailing list
> >>>>>>>>>>> OvmsDev at lists.openvehicles.com
> >>>>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> >>>>>>>>>> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
> >>>>>>>>>> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200711/190c023d/attachment.html
> Subject: Digest Footer
> End of OvmsDev Digest, Vol 102, Issue 16
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200712/ad5e3c9e/attachment-0001.html>
