[Ovmsdev] Double updates - Normal?
Tue Jan 28 06:15:35 HKT 2020
Greg,
that's not normal and doesn't occur to other edge users. Please supply some update logs.
Am 25.01.20 um 04:35 schrieb Greg D.:
> Hi folks,
> I moved my car's OVMSv3 to the Edge firmware a bit ago, and notice that
> every update seems to be doubled.  Besides being a bit annoying, it ends
> up without a previous version to fall back to since both partitions end
> up being the same.
> Is this behavior normal?  Can it be prevented?
> I'm only on Edge because of the bug in obd2ecu, and will probably move
> to EAP after we get an EAP build with the fix in it.  Is the behavior
> the same there?
> I used to be on Main, and all seemed fine there.
> Thanks,
> Greg
