[Ovmsdev] Double updates - Normal?
    Greg D.
    gregd2350 at gmail.com
    Sat Jan 25 11:35:58 HKT 2020
Hi folks,
I moved my car's OVMSv3 to the Edge firmware a bit ago, and notice that
every update seems to be doubled.  Besides being a bit annoying, it ends
up without a previous version to fall back to since both partitions end
up being the same.
Is this behavior normal?  Can it be prevented?
I'm only on Edge because of the bug in obd2ecu, and will probably move
to EAP after we get an EAP build with the fix in it.  Is the behavior
the same there?
I used to be on Main, and all seemed fine there.
Thanks,
Greg
