[Ovmsdev] Scripting: Duktape update to version 2.5.0
Thu Jan 2 17:52:49 HKT 2020
Craig,
I've added handling for the cases of missing SSL or Duktape support, please test.
Am 02.01.20 um 09:29 schrieb Michael Balzer:
> Craig,
> you're right, there is a chance of "func" being used uninitialized, the function called does not set it in all cases.
> The duktape modules are joined into the duktape.c file, the separate sources are only kept for reference -- same as with mongoose.
> My toolchain is gcc version 5.2.0 (crosstool-NG crosstool-ng-1.22.0-98-g4638c4f) for the SPIRAM fix.
> Regarding my latest changes, you seem to build without SSL support, and I forgot some #ifdefs, will add them now.
> Am 02.01.20 um 08:22 schrieb Craig Leres:
>> On 2019-12-29 05:32, Michael Balzer wrote:
>>> yes, that looks like a compiler bug. It doesn't show with crosstool-ng-1.22.0-98-g4638c4f, so it seems that version does include some gcc fixes.
>> Actually I don't think it's necessarily a compiler bug. Looking more closely I see that it isn't directly assigned between when it's declared and the error
>> line. Examining the code shows "func" is probably being updated as a side effect of this call:
>>         if (DUK_LIKELY(duk__resolve_target_fastpath_check(thr, idx_func, &func, call_flags) != 0U)) {
>> The error goes away if func is initialized to NULL when it is declared (confusingly in components/duktape/src/duktape.c, not
>> components/duktape/src-input/duk_js_call.c or components/duktape/src-separate/duk_js_call.c).
>> What toolchain version are you using? I have:
>>     ice 1238 % xtensa-esp32-elf-c++ --version
>>     xtensa-esp32-elf-c++ (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a5) 5.2.0
>> Which is what is specified if I following the links:
>>     https://github.com/openvehicles/esp-idf
>>     https://docs.espressif.com/projects/esp-idf/en/stable/get-started/
>> https://docs.espressif.com/projects/esp-idf/en/stable/get-started/linux-setup.html
>>     Toolchain Setup
>>     for 64-bit Linux:
>> https://dl.espressif.com/dl/xtensa-esp32-elf-linux64-1.22.0-80-g6c4433a-5.2.0.tar.gz
>> Of course my version is built natively for FreeBSD.
>> I'll make a pull request for this. Meanwhile I updated again and changes committed today:
>>     commit b1789e8792197826b1cec71ad0178b879cc2d709
>>     Author: Michael Balzer <balzer at expeedo.de>
>>     Date:   Wed Jan 1 19:08:03 2020 +0100
>>        Webserver: extend /api/execute & loadcmd() by Javascript mode
>> breaks the compile for me, see appended. I'm currently on 9de393f4.
>>         Craig
>> ice 439 % gmake
>> Toolchain path: /home/ice/u0/leres/bin/xtensa-esp32-elf-gcc
>> Toolchain version: crosstool-ng-1.22.0-80-g6c4433a5
>> Compiler version: 5.2.0
>> Python requirements from /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/requirements.txt are satisfied.
>> App "ovms3" version: 3.2.008-54-g9de393f4-dirty
>> CXX /home/ice/u0/leres/src/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms_script/src/ovms_script.o
>> /home/ice/u0/leres/src/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_script/src/ovms_script.cpp: In member function 'bool
>> DuktapeHTTPRequest::StartRequest(duk_context*)':
>> /home/ice/u0/leres/src/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_script/src/ovms_script.cpp:1128:10: error: 'struct mg_connect_opts'
>> has no member named 'ssl_ca_cert'
>>      opts.ssl_ca_cert = "*";
>> /home/ice/u0/leres/src/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_script/src/ovms_script.cpp: In member function 'void
>> DuktapeHTTPRequest::MongooseCallback(mg_connection*, int, void*)':
>> /home/ice/u0/leres/src/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_script/src/ovms_script.cpp:1188:20: error: 'MG_SSL_ERROR' was not
>> declared in this scope
>>          if (err == MG_SSL_ERROR)
>> gmake[1]: *** [/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/make/component_wrapper.mk:290: src/ovms_script.o] Error 1
>> gmake: *** [/home/ice/u0/leres/esp/esp-idf/make/project.mk:552: component-ovms_script-build] Error 2
