[Ovmsdev] Scripting: Duktape update to version 2.5.0
Thu Jan 2 16:29:39 HKT 2020
Craig,
you're right, there is a chance of "func" being used uninitialized, the function called does not set it in all cases.
The duktape modules are joined into the duktape.c file, the separate sources are only kept for reference -- same as with mongoose.
My toolchain is gcc version 5.2.0 (crosstool-NG crosstool-ng-1.22.0-98-g4638c4f) for the SPIRAM fix.
Regarding my latest changes, you seem to build without SSL support, and I forgot some #ifdefs, will add them now.
Am 02.01.20 um 08:22 schrieb Craig Leres:
> On 2019-12-29 05:32, Michael Balzer wrote:
>> yes, that looks like a compiler bug. It doesn't show with crosstool-ng-1.22.0-98-g4638c4f, so it seems that version does include some gcc fixes.
> Actually I don't think it's necessarily a compiler bug. Looking more closely I see that it isn't directly assigned between when it's declared and the error
> line. Examining the code shows "func" is probably being updated as a side effect of this call:
>         if (DUK_LIKELY(duk__resolve_target_fastpath_check(thr, idx_func, &func, call_flags) != 0U)) {
> The error goes away if func is initialized to NULL when it is declared (confusingly in components/duktape/src/duktape.c, not
> components/duktape/src-input/duk_js_call.c or components/duktape/src-separate/duk_js_call.c).
> What toolchain version are you using? I have:
>     ice 1238 % xtensa-esp32-elf-c++ --version
>     xtensa-esp32-elf-c++ (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a5) 5.2.0
> Which is what is specified if I following the links:
>     https://github.com/openvehicles/esp-idf
>     https://docs.espressif.com/projects/esp-idf/en/stable/get-started/
> https://docs.espressif.com/projects/esp-idf/en/stable/get-started/linux-setup.html
>     Toolchain Setup
>     for 64-bit Linux:
> https://dl.espressif.com/dl/xtensa-esp32-elf-linux64-1.22.0-80-g6c4433a-5.2.0.tar.gz
> Of course my version is built natively for FreeBSD.
> I'll make a pull request for this. Meanwhile I updated again and changes committed today:
>     commit b1789e8792197826b1cec71ad0178b879cc2d709
>     Author: Michael Balzer <balzer at expeedo.de>
>     Date:   Wed Jan 1 19:08:03 2020 +0100
>        Webserver: extend /api/execute & loadcmd() by Javascript mode
> breaks the compile for me, see appended. I'm currently on 9de393f4.
>         Craig
> ice 439 % gmake
> Toolchain path: /home/ice/u0/leres/bin/xtensa-esp32-elf-gcc
> Toolchain version: crosstool-ng-1.22.0-80-g6c4433a5
> Compiler version: 5.2.0
> Python requirements from /home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/requirements.txt are satisfied.
> App "ovms3" version: 3.2.008-54-g9de393f4-dirty
> CXX /home/ice/u0/leres/src/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms_script/src/ovms_script.o
> /home/ice/u0/leres/src/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_script/src/ovms_script.cpp: In member function 'bool
> DuktapeHTTPRequest::StartRequest(duk_context*)':
> /home/ice/u0/leres/src/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_script/src/ovms_script.cpp:1128:10: error: 'struct mg_connect_opts'
> has no member named 'ssl_ca_cert'
>      opts.ssl_ca_cert = "*";
> /home/ice/u0/leres/src/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_script/src/ovms_script.cpp: In member function 'void
> DuktapeHTTPRequest::MongooseCallback(mg_connection*, int, void*)':
> /home/ice/u0/leres/src/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_script/src/ovms_script.cpp:1188:20: error: 'MG_SSL_ERROR' was not
> declared in this scope
>          if (err == MG_SSL_ERROR)
> gmake[1]: *** [/home/ice/u0/leres/esp/openvehicles-xtensa-esp32-elf/make/component_wrapper.mk:290: src/ovms_script.o] Error 1
> gmake: *** [/home/ice/u0/leres/esp/esp-idf/make/project.mk:552: component-ovms_script-build] Error 2
