[Ovmsdev] [cesanta/mongoose] LWIP SO_REUSEADDR & ESP32 logging (#894) (fwd)
Fri Feb 14 04:47:35 HKT 2020
Ack. The response was an apology, but I'll rather spend my time on our own issues first.
I asked them about separate PRs with the initial commit. The PR mostly contains Steve's and my changes, I think they are all well done & documented and could
also be merged by cherry picking if necessary.
Am 13.02.20 um 00:53 schrieb Mark Webb-Johnson:
> It is ridiculous. I replied as follows:
>> This PR contains several unrelated pieces - please split, one PR per single functionality piece. The PR should be against the dev branch, and one PR must
>> have only one commit.
> Is there any point? There are 33 pull requests here, dating back to 5 years to 2015. Only three have any response, and this one has sat dead since October
> 2018. It seems Cesanta is simply not interested in community improvements? We could go to the work to re-factor all these improvements and bug fixes into
> individual PRs, but there seems little point unless they get some attention.
> The way we are making our changes, to mongoose.h and mongoose.c directly, isn’t really compatible with how they do things anyway. We should probably be using
> their tools/(un)amalgam.py scripts.
> Let’s see what they reply (to my somewhat rude comment), and go from there. There are so few changes been made to cesanta/mongoose that it may just be easier
> for us to pull from them.
>> On 13 Feb 2020, at 4:49 AM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
>> What happened? Did Mark's commit 58942ce96c5e3e14edb53c804ffcdd4127e226e7
>> finally wake up cesanta? Are we going to resubmit all of our changes
>> as separate pull requests? One person does that, or each author? And
>> to the extent that they may be interdependent, so we need for them to
>> be accepted in order?
>> -- Steve
>> ---------- Forwarded message ----------
>> Date: Wed, 12 Feb 2020 01:35:43 -0800
>> From: Sergey Lyubka <notifications at github.com <mailto:notifications at github.com>>
>> Reply-To: cesanta/mongoose
>> <reply+ABG5G6FIED7L3BL25LSLI4F4KD4W7EVBNHHBDAFYO4 at reply.github.com <mailto:reply+ABG5G6FIED7L3BL25LSLI4F4KD4W7EVBNHHBDAFYO4 at reply.github.com>>
>> To: cesanta/mongoose <mongoose at noreply.github.com <mailto:mongoose at noreply.github.com>>
>> Cc: Stephen Casner <casner at acm.org <mailto:casner at acm.org>>, Mention <mention at noreply.github.com <mailto:mention at noreply.github.com>>
>> Subject: Re: [cesanta/mongoose] LWIP SO_REUSEADDR & ESP32 logging (#894)
>> This PR contains several unrelated pieces - please split, one PR per single functionality piece. The PR should be against the `dev` branch, and one PR must
>> You are receiving this because you were mentioned.
>> Reply to this email directly or view it on GitHub:
>> https://github.com/cesanta/mongoose/pull/894#issuecomment-585116086
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200213/ab5db471/attachment-0001.html>
