[Ovmsdev] Nissan LEAF: HVAC Metrics
Anko Hanse
anko_hanse at hotmail.com
Mon Feb 3 03:52:07 HKT 2020
Hi Jaunius,
Sorry, had a crazy couple of months because of a trip oversees. So did not find the time to pull your branch and test what it does on my leaf.
Kind regards,
Anko
Sent: Sunday, 2 February 2020 10:46 pm
To: OVMS Developers <ovmsdev at lists.openvehicles.com>; Anko Hanse <anko_hanse at hotmail.com>
Subject: Re: [Ovmsdev] Nissan LEAF: HVAC Metrics
Anko,
Did you have time to test out my version? If so any comments? I have been using it for over 2 months and have not noticed anything unusual.
If you haven’t tested it out yet, I plan to build a new version with the suggestions from the folks here and merge it with the latest edge build. And maybe then we can test it?
I am trying to be cautious here as I don’t have much experience coding in C, so would be great for someone to review my code before it is decided to merge it with the main edge repo.
Jaunius Kapkan [Sent from cellphone]
On 2019-11-05, at 09:30, Jaunius Kapkan <jaunius at gmx.com<mailto:jaunius at gmx.com>> wrote:
Thanks for the feedback Anko,
Will adjust the code according to your comments and get back here.
Global Market Operations
Cell: +370 650 11 752<tel:+370%C2%A0650%2011%C2%A0752>
On 2019-11-04, at 22:11, Anko Hanse <anko_hanse at hotmail.com<mailto:anko_hanse at hotmail.com>> wrote:
Hi Jaunius,
Awesome work. Browsed through most of your changes and only have some small comments:
* Naming conventions and code style all look fine
* I do not quite understand why there is both an m_climate_on and an m_climate_off. Is it not sufficient to have just a m_climate_on with value true/false ?
* Similar for the m_climate_vent_off / face / facefeet, etc. Maybe better to change into one variable which is a string or enum with values off / face / facefeet / feet, etc
And the same comment for m_climate_air_recirc / fresh / def.
Look into how it was done for m_battery_type which uses an enumeration of values (enum battery_type).
Or otherwise StandardMetrics.ms_v_charge_state which uses strings ‘stopped’, ‘charging’, ‘done’
I will try and test your code on my 2016 30kwh Leaf.
Kind regards,
Anko Hanse
From: Jaunius Kapkan <jaunius at gmx.com<mailto:jaunius at gmx.com>>
Sent: Tuesday, 5 November 2019 12:09 am
To: OVMS Developers <ovmsdev at lists.openvehicles.com<mailto:ovmsdev at lists.openvehicles.com>>
Subject: [Ovmsdev] Nissan LEAF: HVAC Metrics
Hi,
I have enhanced Nissan LEAF HVAC metrics as well as added additional ones under xnl.cc
I have built and tested the changes and so far all works as intended.
I have also updated documentation.
So I think it is time to merge this in to current edge build, but I just wanted to check with you if all the code style and naming conventios are according to standards.
Would appreciate if someone could review and advise if something needs to be corrected.
Here is the link to the repo and main file I worked on: https://github.com/mjkapkan/Open-Vehicle-Monitoring-System-3/commits/master/vehicle/OVMS.V3/components/vehicle_nissanleaf/src/vehicle_nissanleaf.cpp
Kindly,
On 2019-10-17, at 15:14, Jaunius Kapkan <jaunius at gmx.com<mailto:jaunius at gmx.com>> wrote:
Thanks Mark,
[renaming subject]
In regards to config store. Where would you recommend placing the timers? I was thinking about putting them under vehicle conf:
OVMS# config list vehicle
vehicle (readable writeable)
bms.alerts.enabled: yes
bms.dev.temp.alert:
bms.dev.temp.warn:
bms.dev.voltage.alert:
bms.dev.voltage.warn:
cctimer.evening: 1715-1730
cctimer.morning: 0800-0815
minsoc: 20
name:
timezone: EET-2EEST,M3.5.0/3,M10.5.0/4
timezone_region: Europe/Helsinki
units.distance: K
Any other suggestions?
Jaunius
Sent: Monday, October 14, 2019 at 4:01 AM
From: "Mark Webb-Johnson" <mark at webb-johnson.net<mailto:mark at webb-johnson.net>>
To: "OVMS Developers" <ovmsdev at lists.openvehicles.com<mailto:ovmsdev at lists.openvehicles.com>>
Subject: Re: [Ovmsdev] WifiConsole V1.0
Probably not. The majority of power consumption is from the modems (cellular and wifi).
P.S. If all you need is a 10 second notification, you can pubsub subscribe to the standard event ticker.10.
On 14 Oct 2019, at 7:22 AM, Jaunius Kapkan <jaunius at gmx.com<mailto:jaunius at gmx.com>> wrote:
Delayed events seem to be working fine, thanks for the examples!
However, do you think spamming the events API every 10 seconds might substantially increase power consumption?
* [2:17:04 AM]usr.CCtimer.heartbeat
* [2:17:04 AM]usr.CCtimer.Night.stopped
* [2:17:14 AM]usr.CCtimer.heartbeat
Jaunius
Sent: Sunday, October 13, 2019 at 8:54 PM
From: "Michael Balzer" <dexter at expeedo.de<mailto:dexter at expeedo.de>>
To: ovmsdev at lists.openvehicles.com<mailto:ovmsdev at lists.openvehicles.com>
Sending notifications is now also supported directly:
https://docs.openvehicles.com/en/latest/userguide/scripting.html#ovmsnotify
Am 13.10.19 um 16:09 schrieb Jaunius Kapkan:
> Great,
> Will try that out!
> Jaunius
>> Sent: Sunday, October 13, 2019 at 11:20 AM
>> Jaunius,
>> I've added scheduled (delayed) events & the native OvmsEvents API:
>> https://docs.openvehicles.com/en/latest/userguide/scripting.html#internal-objects-and-functions-methods
>> So you can now also implement millisecond resolution timeouts and intervals in scripts.
>> Am 11.10.19 um 10:36 schrieb Jaunius Kapkan:
>>> Thanks Michael,
>>> 1 second will do just fine as this is for climate control timer plugin I'm doing. Will try to use that event listener. Of course some standartized way would
>>> be better.
>>> Jaunius
>>> *Sent:* Friday, October 11, 2019 at 8:48 AM
>>> *From:* "Michael Balzer" <dexter at expeedo.de<mailto:dexter at expeedo.de>>
>>> *To:* ovmsdev at lists.openvehicles.com<mailto:ovmsdev at lists.openvehicles.com>
>>> *Subject:* Re: [Ovmsdev] WifiConsole V1.0
>>> Jaunius,
>>> setTimeout() is not a standard Javascript function, it's a method of the browser window object.
>>> https://developer.mozilla.org/de/docs/Web/API/WindowTimers/setTimeout
>>> As a workaround, subscribe to the "ticker.1" event as shown in the foglight example:
>>> http://docs.openvehicles.com/en/latest/components/ovms_script/docs/foglight.html#listen-to-events
>>> Resolution is limited to 1 second though. I thought about scheduled events some time ago, i.e. being able to tell the event system to trigger an event after a
>>> specific delay. That would also offer a clean & simple solution for this. Another option would be a script API for the timer service.
>>> I'll have a look at scheduled events.
>>> Am 11.10.19 um 08:29 schrieb Jaunius Kapkan:
>>> Thanks Mark,
>>> One other thing I stumbled upon is that standard setTimeout() does not seem to work. Is there any workaround for this? Sample Code:
>>> |function intervalFunc() { print('Next try in 1.5s') } setInterval(intervalFunc, 1500)|
>>> Basically I need the script to check certain conditions each n seconds.
>>> Jaunius
>>> *Sent:* Thursday, October 10, 2019 at 3:35 AM
>>> *From:* "Mark Webb-Johnson" <mark at webb-johnson.net<mailto:mark at webb-johnson.net>>
>>> *To:* "OVMS Developers" <ovmsdev at lists.openvehicles.com<mailto:ovmsdev at lists.openvehicles.com>>
>>> I think in v2 that could have been the case (as we didn’t have any standardised functions for things like climate control). But in the v3 architecture we
>>> now have these and the vehicle modules should support the standard functions to the best of their abilities.
>>> If we still need mappings like Homelink 1 -> Climate On, then that should be done either by scripts or by some centralised mapping framework.
>>> > On 9 Oct 2019, at 2:19 PM, Jaunius Kapkan <jaunius at gmx.com<mailto:jaunius at gmx.com>> wrote:
>>> > I am making a couple of plugins (initially for leaf) and the JS functions are great for that. However I assume the functions are not unifed accross
>>> different vehicles. For example for leaf to turn on pre-heat you need to issue Homelink 1 instead of ClimateControl. What would be the best way to change
>>> this? Or is this something that need to be changed on the lower level?
>>> > Greetings,
>>> > Jaunius
>>> >> Sent: Tuesday, October 08, 2019 at 9:05 AM
>>> >> Mark,
>>> >> yes, the OLEDs are perfect for these things, bright enough for daylight use with very little energy usage.
>>> >> Thanks for the link to that combined ESP32 module, that's a real beauty, even includes a LiPo supply / charger. I need to check that one out.
>>> >> Regarding our Javascript support, I already had stunned some users with the foglight plugin, they thought stuff like this would need builtin
>>> >> support. That brought me back to my point about how little users know about our capabilities, so I added an explanation to our docs:
>>> >> But we really need something like an OVMS cheat sheet as an overview of what is possible.
>>> >> Regards,
>>> >> Michael
>>> >> Am 08.10.19 um 05:40 schrieb Mark Webb-Johnson:
>>> >>> Michael,
>>> >>> I really like those little OLED SSD1306 based displays. I use them on my esphome+hassio projects like this little water tank level (using an
>>> >>> ESP32, a BME280 pressure/humidity/temperature sensor, waterproof ultrasonic distance sensor, and SSID1306 OLED yellow/blue display):
>>> >>> Adding a display to a project makes it so much more useful and easy to diagnose problems.
>>> >>> AliExpress has them very cheap:
>>> >>> * https://www.aliexpress.com/item/32844104782.html
>>> >>> US$2 for the 0.96” yellow/blue 128x32
>>> >>> US$3 for the 1.3” white 128x64
>>> >>> There is also a 4MB ESP32 with a 0.96” OLED display on-board:
>>> >>> * https://www.aliexpress.com/item/32822105291.html
>>> >>> US$9 plus shipping
>>> >>> Glad that you are finding a use for our JavaScript support. I really think that has so many possibilities.
>>> >>> Regards, Mark
>>> >>>> On 6 Oct 2019, at 10:43 PM, Michael Balzer <dexter at expeedo.de<mailto:dexter at expeedo.de> <mailto:dexter at expeedo.de>> wrote:
>>> >>>> FYI: I've just implemented an OVMS v3 style replacement for the SimpleConsole:
>>> >>>> https://github.com/dexterbg/WifiConsole
>>> >>>> V3 makes it pretty easy now to add stuff like this. It's using a script plugin to provide custom functions via the web API.
>>> >>>> Regards,
>>> >>>> Michael
>>> >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>>> >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>>> >> _______________________________________________
>>> >> OvmsDev mailing list
>>> >> OvmsDev at lists.openvehicles.com<mailto:OvmsDev at lists.openvehicles.com>
>>> >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>>> _______________________________________________ OvmsDev mailing list OvmsDev at lists.openvehicles.com<mailto:OvmsDev at lists.openvehicles.com> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200202/483a9384/attachment-0001.html>
