[Ovmsdev] Nissan LEAF: HVAC Metrics
Jaunius Kapkan jaunius at gmx.com
Sun Feb 2 17:46:21 HKT 2020
Anko,
Did you have time to test out my version? If so any comments? I have been using it for over 2 months and have not noticed anything unusual.
If you haven’t tested it out yet, I plan to build a new version with the suggestions from the folks here and merge it with the latest edge build. And maybe then we can test it?
I am trying to be cautious here as I don’t have much experience coding in C, so would be great for someone to review my code before it is decided to merge it with the main edge repo.
Jaunius Kapkan [Sent from cellphone]
> On 2019-11-05, at 09:30, Jaunius Kapkan <jaunius at gmx.com> wrote:
> Thanks for the feedback Anko,
> Will adjust the code according to your comments and get back here.
> Global Market Operations
> Cell:      +370 650 11 752
>>> On 2019-11-04, at 22:11, Anko Hanse <anko_hanse at hotmail.com> wrote:
>> Hi Jaunius,
>> Awesome work. Browsed through most of your changes and only have some small comments:
>> Naming conventions and code style all look fine
>> I do not quite understand why there is both an m_climate_on and an m_climate_off.  Is it not sufficient to have just a m_climate_on with value true/false ?
>> Similar for the m_climate_vent_off / face / facefeet, etc. Maybe better to change into one variable which is a string or enum with values off / face / facefeet / feet, etc
>> And the same comment for m_climate_air_recirc / fresh / def.
>> Look into how it was done for m_battery_type which uses an enumeration of values (enum battery_type).
>> Or otherwise StandardMetrics.ms_v_charge_state which uses strings ‘stopped’, ‘charging’, ‘done’
>> I will try and test your code on my 2016 30kwh Leaf.
>> Kind regards,
>> Anko Hanse
>> From: Jaunius Kapkan <jaunius at gmx.com>
>> Sent: Tuesday, 5 November 2019 12:09 am
>> To: OVMS Developers <ovmsdev at lists.openvehicles.com>
>> Subject: [Ovmsdev] Nissan LEAF: HVAC Metrics
>> Hi,
>> I have enhanced Nissan LEAF HVAC metrics as well as added additional ones under xnl.cc
>> I have built and tested the changes and so far all works as intended.
>> I have also updated documentation.
>> So I think it is time to merge this in to current edge build, but I just wanted to check with you if all the code style and naming conventios are according to standards.
>> Would appreciate if someone could review and advise if something needs to be corrected.
>> Here is the link to the repo and main file I worked on: https://github.com/mjkapkan/Open-Vehicle-Monitoring-System-3/commits/master/vehicle/OVMS.V3/components/vehicle_nissanleaf/src/vehicle_nissanleaf.cpp
>> Kindly,
>> On 2019-10-17, at 15:14, Jaunius Kapkan <jaunius at gmx.com> wrote:
>> Thanks Mark,
>> [renaming subject]
>> In regards to config store. Where would you recommend placing the timers? I was thinking about putting them under vehicle conf:
>> OVMS# config list vehicle
>> vehicle (readable writeable)
>>   bms.alerts.enabled: yes
>>   bms.dev.temp.alert:
>>   bms.dev.temp.warn:
>>   bms.dev.voltage.alert:
>>   bms.dev.voltage.warn:
>>   cctimer.evening: 1715-1730
>>   cctimer.morning: 0800-0815
>>   minsoc: 20
>>   name:
>>   timezone: EET-2EEST,M3.5.0/3,M10.5.0/4
>>   timezone_region: Europe/Helsinki
>>   units.distance: K
>> Any other suggestions?
>> Jaunius
>> Sent: Monday, October 14, 2019 at 4:01 AM
>> From: "Mark Webb-Johnson" <mark at webb-johnson.net>
>> To: "OVMS Developers" <ovmsdev at lists.openvehicles.com>
>> Subject: Re: [Ovmsdev] WifiConsole V1.0
>> Probably not. The majority of power consumption is from the modems (cellular and wifi).
>> Regards, Mark
>> P.S. If all you need is a 10 second notification, you can pubsub subscribe to the standard event ticker.10.
>> On 14 Oct 2019, at 7:22 AM, Jaunius Kapkan <jaunius at gmx.com> wrote:
>> Delayed events seem to be working fine, thanks for the examples!
>> However, do you think spamming the events API every 10 seconds might substantially increase power consumption?
>> [2:17:04 AM]usr.CCtimer.heartbeat
>> [2:17:04 AM]usr.CCtimer.Night.stopped
>> [2:17:14 AM]usr.CCtimer.heartbeat
>> Jaunius
>> Sent: Sunday, October 13, 2019 at 8:54 PM
>> From: "Michael Balzer" <dexter at expeedo.de>
>> To: ovmsdev at lists.openvehicles.com
>> Sending notifications is now also supported directly:
>> https://docs.openvehicles.com/en/latest/userguide/scripting.html#ovmsnotify
>> Am 13.10.19 um 16:09 schrieb Jaunius Kapkan:
>> > Great,
>> > Will try that out!
>> > Regards,
>> > Jaunius
>> >> Sent: Sunday, October 13, 2019 at 11:20 AM
>> >> Jaunius,
>> >> I've added scheduled (delayed) events & the native OvmsEvents API:
>> >> https://docs.openvehicles.com/en/latest/userguide/scripting.html#internal-objects-and-functions-methods
>> >> So you can now also implement millisecond resolution timeouts and intervals in scripts.
>> >> Regards,
>> >> Michael
>> >> Am 11.10.19 um 10:36 schrieb Jaunius Kapkan:
>> >>> Thanks Michael,
>> >>> 1 second will do just fine as this is for climate control timer plugin I'm doing. Will try to use that event listener. Of course some standartized way would
>> >>> be better.
>> >>> Regards,
>> >>> Jaunius
>> >>> *Sent:* Friday, October 11, 2019 at 8:48 AM
>> >>> *From:* "Michael Balzer" <dexter at expeedo.de>
>> >>> *To:* ovmsdev at lists.openvehicles.com
>> >>> *Subject:* Re: [Ovmsdev] WifiConsole V1.0
>> >>> Jaunius,
>> >>> setTimeout() is not a standard Javascript function, it's a method of the browser window object.
>> >>> https://developer.mozilla.org/de/docs/Web/API/WindowTimers/setTimeout
>> >>> As a workaround, subscribe to the "ticker.1" event as shown in the foglight example:
>> >>> http://docs.openvehicles.com/en/latest/components/ovms_script/docs/foglight.html#listen-to-events
>> >>> Resolution is limited to 1 second though. I thought about scheduled events some time ago, i.e. being able to tell the event system to trigger an event after a
>> >>> specific delay. That would also offer a clean & simple solution for this. Another option would be a script API for the timer service.
>> >>> I'll have a look at scheduled events.
>> >>> Regards,
>> >>> Michael
>> >>> Am 11.10.19 um 08:29 schrieb Jaunius Kapkan:
>> >>> Thanks Mark,
>> >>> One other thing I stumbled upon is that standard setTimeout() does not seem to work. Is there any workaround for this? Sample Code:
>> >>> |function intervalFunc() { print('Next try in 1.5s') } setInterval(intervalFunc, 1500)|
>> >>> Basically I need the script to check certain conditions each n seconds.
>> >>> Regards,
>> >>> Jaunius
>> >>> *Sent:* Thursday, October 10, 2019 at 3:35 AM
>> >>> *From:* "Mark Webb-Johnson" <mark at webb-johnson.net>
>> >>> *To:* "OVMS Developers" <ovmsdev at lists.openvehicles.com>
>> >>> I think in v2 that could have been the case (as we didn’t have any standardised functions for things like climate control). But in the v3 architecture we
>> >>> now have these and the vehicle modules should support the standard functions to the best of their abilities.
>> >>> If we still need mappings like Homelink 1 -> Climate On, then that should be done either by scripts or by some centralised mapping framework.
>> >>> Regards, Mark.
>> >>> > On 9 Oct 2019, at 2:19 PM, Jaunius Kapkan <jaunius at gmx.com> wrote:
>> >>> > I am making a couple of plugins (initially for leaf) and the JS functions are great for that. However I assume the functions are not unifed accross
>> >>> different vehicles. For example for leaf to turn on pre-heat you need to issue Homelink 1 instead of ClimateControl. What would be the best way to change
>> >>> this? Or is this something that need to be changed on the lower level?
>> >>> > Greetings,
>> >>> > Jaunius
>> >>> >> Sent: Tuesday, October 08, 2019 at 9:05 AM
>> >>> >> Mark,
>> >>> >> yes, the OLEDs are perfect for these things, bright enough for daylight use with very little energy usage.
>> >>> >> Thanks for the link to that combined ESP32 module, that's a real beauty, even includes a LiPo supply / charger. I need to check that one out.
>> >>> >> Regarding our Javascript support, I already had stunned some users with the foglight plugin, they thought stuff like this would need builtin
>> >>> >> support. That brought me back to my point about how little users know about our capabilities, so I added an explanation to our docs:
>> >>> >> But we really need something like an OVMS cheat sheet as an overview of what is possible.
>> >>> >> Regards,
>> >>> >> Michael
>> >>> >> Am 08.10.19 um 05:40 schrieb Mark Webb-Johnson:
>> >>> >>> Michael,
>> >>> >>> I really like those little OLED SSD1306 based displays. I use them on my esphome+hassio projects like this little water tank level (using an
>> >>> >>> ESP32, a BME280 pressure/humidity/temperature sensor, waterproof ultrasonic distance sensor, and SSID1306 OLED yellow/blue display):
>> >>> >>> Adding a display to a project makes it so much more useful and easy to diagnose problems.
>> >>> >>> AliExpress has them very cheap:
>> >>> >>> * https://www.aliexpress.com/item/32844104782.html
>> >>> >>> US$2 for the 0.96” yellow/blue 128x32
>> >>> >>> US$3 for the 1.3” white 128x64
>> >>> >>> There is also a 4MB ESP32 with a 0.96” OLED display on-board:
>> >>> >>> * https://www.aliexpress.com/item/32822105291.html
>> >>> >>> US$9 plus shipping
>> >>> >>> Glad that you are finding a use for our JavaScript support. I really think that has so many possibilities.
>> >>> >>> Regards, Mark
>> >>> >>>> On 6 Oct 2019, at 10:43 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> >>> >>>> FYI: I've just implemented an OVMS v3 style replacement for the SimpleConsole:
>> >>> >>>> https://github.com/dexterbg/WifiConsole
>> >>> >>>> V3 makes it pretty easy now to add stuff like this. It's using a script plugin to provide custom functions via the web API.
>> >>> >>>> Regards,
>> >>> >>>> Michael
>> >>> >> Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
>> >>> >> Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
>> >>> >> _______________________________________________
>> >>> >> OvmsDev mailing list
>> >>> >> OvmsDev at lists.openvehicles.com
>> >>> >> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
>> >>> _______________________________________________ OvmsDev mailing list OvmsDev at lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200202/19f13b9d/attachment-0001.html>
