[Ovmsdev] Addition to OVMS Developer Guide
Mon Dec 28 16:45:44 HKT 2020
Steve,
thanks, looks good. Instead of removing the section from the Google doc,
I suggest replacing it by a link to the RTD page.
Content suggestions:
* Please check for typos and grammar.
* I think it's worth mentioning RegisterCommand() tolerates duplicate
registrations, allowing to forget about the init sequence.
* I opt to change the side note "explanatory text can be included"
into a strong recommendation, as we still have many commands that
lack explanations, and we should avoid the impression of that being
the accepted standard. Users shall gain confidence about using a
command by reading the command's usage info.
* The cleanup scheme (command deregistration) is missing.
* An explanation of the "execute" and "validate" handler signatures
probably also fits into the scope of this page.
Am 28.12.20 um 03:59 schrieb Stephen Casner:
> Michael,
> OK, I converted my CLI documentation from the Google Doc into Sphinx.
> I added it at the top of the list of Developer Guides since the CLI is
> one of the first points of interaction for a developer (after the web
> installation wizard and configuration), but feel free to move it
> somewhere else that might be more appropriate.
> There may be markup conventions to adjust.
> I'm inclined to delete this section from the Google Doc now to avoid
> having changes diverge. Would you (and Mark) agree?
> I started with an automated conversion from the Google Doc source to
> rST markup, then manually cleaned it up. It wasn't too hard. Maybe
> that process could be use to move over the remained of the Google
> Doc.
> -- Steve
> On Sun, 27 Dec 2020, Michael Balzer wrote:
>> Steve,
>> yes, we're in the long-term migration of the developer documentation to
>> Sphinx.
>> → http://lists.openvehicles.com/pipermail/ovmsdev/2019-July/006196.html
>> The Google document still serves as an introduction for new firmware and
>> hardware developers. New parts have been added to sphinx, but existing
>> sections haven't been transformed yet. The parts in Sphinx are currently more
>> targeted towards developers using the system, but just because they've been
>> added after we decided to move to Sphinx.
>> Am 26.12.20 um 22:42 schrieb Stephen Casner:
>>> Michael,
>>> The documentation I added was in the Google Doc OVMS Developer Guide:
>>> https://docs.google.com/document/d/1q5M9Lb5jzQhJzPMnkMKwy4Es5YK12ACQejX_NWEixr0/
>>> Is that document supposed to be replaced by the github-based
>>> Sphinx/RTD documentation that you mention? The Google Doc appears
>>> quite unfinished in that there are many blank pages between sections
>>> and the TOC is not updated.
>>> -- Steve
>>> On Tue, 22 Dec 2020, Michael Balzer wrote:
>>>> Thanks, Steve.
>>>> That reminds me of looking for a solution to generate RTD pages from the
>>>> C++
>>>> sources, e.g. by sphinx-autodoc or similar. I prefer looking into the
>>>> source,
>>>> but have to admit the API documentation of the esp-idf is usable. We
>>>> probably
>>>> need to restructure most existing method & class comments and add the
>>>> missing
>>>> ones, but maintaining the API documentation would be easy afterwards.
>>>> Regards,
>>>> Michael
>>>> Am 22.12.20 um 09:14 schrieb Stephen Casner:
>>>>> At Mark's request I have added a description of how to add commands to
>>>>> the console command interpreter including the usage string syntax.
>>>>> This should be considered a draft at this point; questions and
>>>>> comments are welcome.
>>>>> I added this under Vehicle Firmware Overview, but that might not be
>>>>> the right place. There is no general description of the core
>>>>> firmware.
>>>>> -- Steve
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201228/ede5e22f/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201228/ede5e22f/attachment.sig>
