[Ovmsdev] Addition to OVMS Developer Guide
Mon Dec 28 10:59:00 HKT 2020
Michael,
OK, I converted my CLI documentation from the Google Doc into Sphinx.
I added it at the top of the list of Developer Guides since the CLI is
one of the first points of interaction for a developer (after the web
installation wizard and configuration), but feel free to move it
somewhere else that might be more appropriate.
There may be markup conventions to adjust.
I'm inclined to delete this section from the Google Doc now to avoid
having changes diverge.  Would you (and Mark) agree?
I started with an automated conversion from the Google Doc source to
rST markup, then manually cleaned it up.  It wasn't too hard.  Maybe
that process could be use to move over the remained of the Google
Doc.
On Sun, 27 Dec 2020, Michael Balzer wrote:
> Steve,
> yes, we're in the long-term migration of the developer documentation to
> Sphinx.
>http://lists.openvehicles.com/pipermail/ovmsdev/2019-July/006196.html
> The Google document still serves as an introduction for new firmware and
> hardware developers. New parts have been added to sphinx, but existing
> sections haven't been transformed yet. The parts in Sphinx are currently more
> targeted towards developers using the system, but just because they've been
> added after we decided to move to Sphinx.
> Am 26.12.20 um 22:42 schrieb Stephen Casner:
> > Michael,
> > The documentation I added was in the Google Doc OVMS Developer Guide:
> > https://docs.google.com/document/d/1q5M9Lb5jzQhJzPMnkMKwy4Es5YK12ACQejX_NWEixr0/
> > Is that document supposed to be replaced by the github-based
> > Sphinx/RTD documentation that you mention?  The Google Doc appears
> > quite unfinished in that there are many blank pages between sections
> > and the TOC is not updated.
> >                                                          -- Steve
> > On Tue, 22 Dec 2020, Michael Balzer wrote:
> > > Thanks, Steve.
> > > That reminds me of looking for a solution to generate RTD pages from the
> > > C++
> > > sources, e.g. by sphinx-autodoc or similar. I prefer looking into the
> > > source,
> > > but have to admit the API documentation of the esp-idf is usable. We
> > > probably
> > > need to restructure most existing method & class comments and add the
> > > missing
> > > ones, but maintaining the API documentation would be easy afterwards.
> > > Regards,
> > > Michael
> > > Am 22.12.20 um 09:14 schrieb Stephen Casner:
> > > > At Mark's request I have added a description of how to add commands to
> > > > the console command interpreter including the usage string syntax.
> > > > This should be considered a draft at this point; questions and
> > > > comments are welcome.
> > > > I added this under Vehicle Firmware Overview, but that might not be
> > > > the right place.  There is no general description of the core
> > > > firmware.
> > > >                                                           -- Steve
> > > > _______________________________________________
> > > > OvmsDev mailing list
> > > > OvmsDev at lists.openvehicles.com
> > > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> > > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
> > > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
