[Ovmsdev] WiFi client not switching to better AP
Wed Dec 23 03:04:17 HKT 2020
Steve,
I've added the configuration, please test.
Am 21.12.20 um 13:22 schrieb Michael Balzer:
> Steve,
> go ahead with the commit, I'll add the configuration for the reconnect
> strategy.
> Am 21.12.20 um 03:29 schrieb Stephen Casner:
>> Michael,
>> That was going to be my next question for you: Is it possible to
>> connect to a different AP without tearing down all the connections
>> like esp_wifi_disconnect() does. I studied the Wifi driver
>> documentation for a while trying to find an answer to that question,
>> but it didn't really talk about that scenario.
>> It sounds like my proposed change worked OK for you, so shall I go
>> ahead and commit it? Or would you do something differently to include
>> your idea about an option to automatically reconnect on "bad" events?
>> -- Steve
>> On Sun, 20 Dec 2020, Michael Balzer wrote:
>>> Steve,
>>> I just bewildered my neighbours by walking through the house,
>>> holding a black
>>> box into the corners while staring onto my laptop screen... ;)
>>> Works nicely. With "wifi reconnect" on the event, it scans
>>> immediately for the
>>> next wifi net, without the script it doesn't scan until it actually
>>> loses the
>>> connection, so works as before. I've seen no duplicate "good" or
>>> "bad" events
>>> as well.
>>> We could add an option for that reconnect strategy to the network
>>> configuration already, so users don't need to create an event script
>>> to get
>>> this behaviour.
>>> I think the second part, keeping TCP connections alive on AP
>>> changes, will
>>> require some more changes - if it's possible at all with the current
>>> Wifi &
>>> LwIP stack.
>>> Am 19.12.20 um 21:51 schrieb Stephen Casner:
>>>> OK, a proposed change is attached.
>>>> -- Steve
>>>> On Sat, 19 Dec 2020, Michael Balzer wrote:
>>>>> The reason to emit that event is to inform all potential listeners
>>>>> of the
>>>>> new
>>>>> state, so they can keep their internal state synchronized.
>>>>> Regards,
>>>>> Michael
>>>>> Am 19.12.20 um 19:09 schrieb Stephen Casner:
>>>>>> We don't need to emit the network.wifi.sta.bad event to cause
>>>>>> WifiDisconnect() to be called because that is already happening. Is
>>>>>> there some other reason for emitting that event?
>>>>>> -- Steve
>>>>>>> It's also the event emission, keeping the handling close
>>>>>>> together is
>>>>>>> for
>>>>>>> code
>>>>>>> readability. The compiler will probably inline that call anyway.
>>>>>>> Regards,
>>>>>>> Michael
>>>>>>> Am 19.12.20 um 18:32 schrieb Stephen Casner:
>>>>>>>>> If we need to force good/bad state, I suggest adding a method for
>>>>>>>>> this
>>>>>>>>> right
>>>>>>>>> after WifiStaCheckSQ().
>>>>>>>> Rather than just adding m_wifi_good = false in some place like
>>>>>>>> WifiStaStop()? Another method doesn't seem warranted. That is a
>>>>>>>> member variable, not something local to WifiStaCheckSQ().
>>>>>>>> Steve
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.openvehicles.com
>>>>>>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201222/cb65ae0d/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201222/cb65ae0d/attachment.sig>
