[Ovmsdev] How fast can the poller go?
Tue Dec 22 21:44:34 HKT 2020
Steve,
have a look at API methods PollSetThrottling() and
PollSetResponseSeparationTime():
void PollSetThrottling(uint8_t sequence_max) { m_poll_sequence_max =
sequence_max; }
uint8_t           m_poll_sequence_max;    // Polls allowed to be sent in
sequence per time tick (second), default 1, 0 = no limit
  * PollSetResponseSeparationTime: configure ISO TP multi frame response
timing
  *  See: https://en.wikipedia.org/wiki/ISO_15765-2
  *  @param septime
  *    Separation Time (ST), the minimum delay time between frames.
Default: 25 milliseconds
  *    ST values up to 127 (0x7F) specify the minimum number of
milliseconds to delay between frames,
  *    while values in the range 241 (0xF1) to 249 (0xF9) specify delays
increasing from
  *    100 to 900 microseconds.
  *  The configuration is kept unchanged over calls to PollSetPidList()
or PollSetState().
The defaults are conservative & very cooperative for both parameters,
but keep in mind you're not alone on the bus.
Am 22.12.20 um 14:34 schrieb Steve Davies:
> Hi,
> On the i3 I have to poll for everything - at least if I use the OBD2 port.
> It seems that the poller only sends one request per second.  That's
> how it looks in the logs.
> This severely limits how many pids I can poll and basically means I
> might as well not bother with any of the "real time" metrics.
> Is there a reason why PollerSend couldn't look through the whole poll
> list and poll all the entries that are due/overdue on each call?  At
> the moment it just looks until if finds one to do and then it returns.
> Or maybe if we can't take too long then say do 10 on each call?
> Thanks,
> Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201222/9be06149/attachment.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201222/9be06149/attachment.sig>
