[Ovmsdev] Dcdc converter metrics
Sun Dec 20 17:37:56 HKT 2020
I think voltage should be practically always identical at the DC
converter output to the 12V battery, as there normally isn't anything
between, and it should also be identical to the 12V reading of the
module, as it's powered directly by the 12V circuit.
12V current will probably normally only be available as the DC converter
output, which partially charges the 12V battery, but probably mostly
powers the 12V components. So yes, that's probably misplaced unter
"v.b." – my bad.
Does any of your cars provide a 12V current reading at the battery? Or a
temperature of that battery? These could help diagnose 12V battery
issues early. But the voltage is normally sufficient to estimate
degradation.
That's how my Twizy 12V battery looked like when it finally died…
luckily not by rapid unscheduled disassembly, but it sure smelled like due…
Am 20.12.20 um 03:58 schrieb Steve Davies:
 > On the i3 so far I have lots of info on the DcDc converter - I can
see the current the converter is putting out.  but so far I didn’t find
current figure for the actual 12v battery.
Am 19.12.20 um 21:27 schrieb sharkcow:
> Good point! For the e-Up we can also get voltage & current of the dcdc
> converter :)
> Am 19.12.20 um 20:51 schrieb Derek Caudwell:
>> If additional metrics are being added for the dcdc converter I suggest
>> including the following as well as temp:
>> v.c.12v.voltage   14.2V
>> v.c.12v.current   10A
>> v.c.12v.power     0.14kW
>> For the Leaf I have found the dcdc output voltage, still looking for a
>> current reading to calculate the power output.
>> Cheers Derek
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201220/438fd4ea/attachment-0001.htm>
Type: image/jpeg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201220/438fd4ea/attachment-0001.jpeg>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201220/438fd4ea/attachment-0001.sig>
