[Ovmsdev] Help me get my first data item on the I3
Steve Davies steve at telviva.co.za
Sat Dec 12 23:12:46 HKT 2020
Hi Michael,
So I've written something to poll the SOC%.
At this stage I'm trying to debug.  I'm running my code - I configured for
my BMWI3 module and my car.
I set log level debug v-bmwi3, log level verbose canlog, and log level
canopen.
I can see that can1 is running - I'm sending some packets (I had it poll
once per 60 seconds and indeed I'm sending one packet per minute).
can can1 status says:
OVMS# can can1 status
CAN:       can1
Mode:      Active
Speed:     500000
DBC:       none
Interrupts:                5557
Rx pkt:                    5548
Rx err:                       0
Rx ovrflw:                    0
Tx pkt:                       9
Tx delays:                    0
Tx err:                       0
Tx ovrflw:                    0
Wdg Resets:                   0
Err Resets:                   0
Wdg Timer:                    0 sec(s)
Err flags: 0x00000000
I put "ESP_LOGD(TAG, "BMWI3: got SOC=%3.1f%%", soc);" in my code after
parsing the SOC.
But I'm not seeing that log message in the console.
Can I enable a trace of CAN1 (without drowning my box!).  Can I see what
gets transmitted?
Thanks,
Steve
On Sat, 12 Dec 2020 at 13:49, Michael Balzer <dexter at expeedo.de> wrote:
> Steve,
> use the vehicle_obdii module to get into OBD polling on the OVMS.
> You begin by defining the poll requests to be sent in at least one array
> of type OvmsVehicle::poll_pid_t. A request consists of
>    - the transmission address (CAN ID), this may be a specific address or
>    the broadcast address 0x7df
>    - the expected response address (CAN ID), or 0 in case of a broadcast
>    - the type of the request; OBD also calls this "mode", e.g. 0x22,
>    there are preprocessor definitions for all supported types, e.g. 0x22 =
>    VEHICLE_POLL_TYPE_OBDIIEXTENDED
>    - optionally the PID to access (depending on the request type, may be
>    none / 8 bit / 16 bit)
>    - the poll interval; this may be specified for up to 4 vehicle states
>    (normally used to switch intervals according to the car's operation mode,
>    like sleeping / driving / charging)
>    - optionally the CAN bus to use for the request
> For your example of polling the SOC, this would be:
>    - transmission address: 0x6F1
>    - response address: 0x607
>    - type: 0x22 or VEHICLE_POLL_TYPE_OBDIIEXTENDED
>    - PID: 0xDDBC
>    - poll interval: as you like, e.g. { 0, 10, 60 } -- assuming for
>    sleeping, driving, charging
> End the array with an all zero entry. The poller will automatically loop
> over the list.
> Call OvmsVehicle::PollSetPidList() to set the array to be used, call
> OvmsVehicle::PollSetState() to set the vehicle state (defining the poll
> intervals).
> Override OvmsVehicle::IncomingPollReply() with your result processing.
> The method will be called by the framework for each response part. The
> framework also supplies polling state variables you can use (see vehicle.h).
> A typical pattern to collect multiple frames is:
> void OvmsVehicleRenaultTwizy::IncomingPollReply(
>   canbus* bus, uint16_t type, uint16_t pid, uint8_t* data, uint8_t length,
> uint16_t mlremain)
>   string& rxbuf = twizy_obd_rxbuf;
>   // init / fill rx buffer:
>   if (m_poll_ml_frame == 0) {
>     rxbuf.clear();
>     rxbuf.reserve(length + mlremain);
>   rxbuf.append((char*)data, length);
>   if (mlremain)
>     return;
>   // complete:
>   switch (pid) {
> This pattern collects the payload in a string buffer, regardless of the
> length.
> Decoding and converting the payload to metrics is up to you, but normally
> is simple.
> For your example:
>>   // complete:
>   switch (pid) {
>     case 0xDDBC: {
>       unsigned int soc_raw = ((unsigned int)rxbuf[0] << 8) | (unsigned
> int)rxbuf[1];
>       float soc = soc_raw / 10.0f;
>       StdMetrics.ms_v_bat_soc->SetValue(soc);
>       break;
> On your question:
> 2020-11-15 10:34:36.474 <-- 607␣F1␣03␣7F␣22␣78␣⏎            // this is
> some unrelated packet?
> Actually it's related, it's the first reply of the device and means "I'm
> busy, but stand by, results will come soon". The poller handles these.
> If you want to follow the poller operation, activate debug logging for the
> vehicle module: log level debug vehicle
> There's more on the poller, but that should get you going.
> Am 12.12.20 um 10:19 schrieb Steve Davies:
> Hi,
> Can I ask someone to help me get started with pulling data off the OBD-2
> on the I3.
> I have info on what works via an LM327 and I know the pids, but it would
> help me for some pointers as to how to do it on the OVMS.
> You know - the goal to get the first one working.
> Here's an example definition - the SOC of the main battery.  This is
> extracted from decompiling a definition file for ediasbas/ediasblib:
> (The "_EN" text is translated using Google cloud translate so the German
> is the original)
> The "job" is defined like so:
>             "SERVICE" : "22",
>             "ID" : "0xDDBC",
>             "DIV" : "-",
>             "INFO" : "aktueller Anzeige Soc",
>             "RES_TABELLE" : "RES_0xDDBC_D",
>             "ARG_TABELLE" : "-",
>             "EINHEIT" : "-",
>             "DATENTYP" : "-",
>             "ARG" : "ANZEIGE_SOC",
>             "LABEL" : "-",
>             "ADD" : "-",
>             "MUL" : "-",
>             "INFO_EN" : "current advertisement Soc",
>             "L/H" : "-",
>             "RESULTNAME" : "-",
>             "NAME" : "-",
>             "SG_ADR" : "-"
> The "results" are defined like so:
>       "RES_0XDDBC_D" : [
>             "DIV" : "10.0",
>             "DATENTYP" : "unsigned int",
>             "EINHEIT" : "%",
>             "MASKE" : "-",
>             "RESULTNAME" : "STAT_ANZEIGE_SOC_WERT",
>             "L/H" : "high",
>             "MUL" : "1.0",
>             "ADD" : "0.0",
>             "NAME" : "-"
>             "NAME" : "-",
>             "ADD" : "0.0",
>             "MUL" : "1.0",
>             "L/H" : "high",
>             "RESULTNAME" : "STAT_MAXIMALE_ANZEIGE_SOC_WERT",
>             "INFO" : "obere Grenze des Anzeige Soc",
>             "MASKE" : "-",
>             "INFO_EN" : "upper limit of the display Soc",
>             "EINHEIT" : "%",
>             "DIV" : "10.0"
>             "RESULTNAME" : "STAT_MINIMALE_ANZEIGE_SOC_WERT",
>             "L/H" : "high",
>             "MUL" : "1.0",
>             "NAME" : "-",
>             "ADD" : "0.0",
>             "DIV" : "10.0",
>             "INFO_EN" : "lower limit of the display Soc",
>             "EINHEIT" : "%",
>             "INFO" : "untere Grenze des Anzeige Soc",
>             "MASKE" : "-"
> I read it that three unsigned ints (16 bits each) are returned.
> Each is divided by 10 to return a "%".
> I traced an app that can retrieves this parameter using an LM327 based
> OBD2 interface.
> That app initialises the LM327 like so:
> 2020-11-15 10:34:28.831 --> ATD Return all settings to default
> 2020-11-15 10:34:28.849 --> ATE0 Disable command echo
> 2020-11-15 10:34:28.861 --> ATH1 Show CAN message headers
> 2020-11-15 10:34:28.875 --> ATAL Allow long messages
> 2020-11-15 10:34:28.887 --> ATPBE101 Set programmable param 0x2c to 0xE1,
> 0x2d to 0x01
>        - 2c=0xE1:
>           - 11 bit IDs
>           - variable data-length code
>           - 11 or 29 bit received IDs
>           - use data format ISO 15765-4 (CAN)
>        - 2d=0x01
>           - Use rate divisor of 1
> 2020-11-15 10:34:28.901 --> ATSPB Use protocol USER1 CAN (as set above I
> think)
> 2020-11-15 10:34:28.949 --> ATBI Bypass initialisation - apparently a bad
> idea... ?
> 2020-11-15 10:34:28.964 --> ATSH6F1 Set header bytes to 0x6F1 ( 0x06F1 ? )
> 2020-11-15 10:34:28.978 --> ATAT0 Disable adaptive timing - wait up to
> ATSF time
> 2020-11-15 10:34:28.992 --> ATSTFF Maximum wait
> Then, when it fetches this PID it does the following:
> 2020-11-15 10:34:35.101 --> ATCRA607⏎                       // Listen for
> 0x607
> 2020-11-15 10:34:35.114 <-- OK⏎⏎>
> 2020-11-15 10:34:35.115 --> ATCEA07⏎                        // "extended
> address" 0x07 [matches 607?]
> 2020-11-15 10:34:35.127 <-- OK⏎⏎>
> 2020-11-15 10:34:35.129 --> ATFCSH6F1⏎                      // Flow
> control header
> 2020-11-15 10:34:35.141 <-- OK⏎⏎>
> 2020-11-15 10:34:35.143 --> ATFCSD07300800⏎                 // Flow
> control data
> 2020-11-15 10:34:35.156 <-- OK⏎⏎>
> 2020-11-15 10:34:35.157 --> ATFCSM1⏎                        // Flow
> control mode
> 2020-11-15 10:34:35.170 <-- OK⏎⏎>
> 2020-11-15 10:34:36.367 --> 22␣DD␣BC⏎                       // asking for
> "extended" PID 0xDDBC
> 2020-11-15 10:34:36.539 <-- 607␣F1␣10␣09␣62␣DD␣BC␣02␣4C␣⏎   // reply -->
> 0x24C = 588 = 58.8 SOC
>      607␣F1␣21␣03␣A6␣00␣69␣FF␣FF␣⏎                          // 0x03A6 = =
> 93.4%, 0x0069 = 10.5%
> 2020-11-15 10:34:37.598 <-- ⏎>
> Remember the LM327 takes the sent bytes and wraps with into a full CAN
> message - though I'm not sure exactly how that comes out - I presume that
> "extended address" goes in somewhere.
> --> 22 DD BC is the PID
> <-- 2 part reply.  First has the SOC.  Second has 0x03A6 (934) and 0x0069
> (105)
> First int is 588 or 58.8% which is the physical SOC of the battery.
> 934 is 93.4 which is the physical SOC level which the car displays as
> "100%" (i3 keeps some headroom "reserved").
> 105 is 10.5 which is the physical SOC level that the car displays as 0%.
> I'd appreciate some help to give me a head-start to be able to retrieve
> this attribute on the OVMS box.
> Thanks,
> Steve
> OvmsDev mailing listOvmsDev at lists.openvehicles.comhttp://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201212/632508ad/attachment-0003.htm>
