[Ovmsdev] Help me get my first data item on the I3
Sat Dec 12 23:27:39 HKT 2020
Steve,
with log level verbose for canlog, you can simply activate CAN logging via:
can log start monitor crtd
…that will log all frames, if that's too much, add a filter like this:
can log start monitor crtd 600-7ff
Use can log stop to …well, you'll guess it ;-)
And as I said, to get the log messages of the vehicle poller, set log
level debug on "vehicle".
Btw: in case you missed it, have a look at Config→Logging for persistent
levels & file logging.
Am 12.12.20 um 16:12 schrieb Steve Davies:
> Hi Michael,
> So I've written something to poll the SOC%.
> At this stage I'm trying to debug. I'm running my code - I configured
> for my BMWI3 module and my car.
> I set log level debug v-bmwi3, log level verbose canlog, and log level
> canopen.
> I can see that can1 is running - I'm sending some packets (I had it
> poll once per 60 seconds and indeed I'm sending one packet per minute).
> can can1 status says:
> OVMS# can can1 status
> CAN: can1
> Mode: Active
> Speed: 500000
> DBC: none
> Interrupts: 5557
> Rx pkt: 5548
> Rx err: 0
> Rx ovrflw: 0
> Tx pkt: 9
> Tx delays: 0
> Tx err: 0
> Tx ovrflw: 0
> Wdg Resets: 0
> Err Resets: 0
> Wdg Timer: 0 sec(s)
> Err flags: 0x00000000
> I put "ESP_LOGD(TAG, "BMWI3: got SOC=%3.1f%%", soc);" in my code after
> parsing the SOC.
> But I'm not seeing that log message in the console.
> Can I enable a trace of CAN1 (without drowning my box!). Can I see
> what gets transmitted?
> Thanks,
> Steve
> On Sat, 12 Dec 2020 at 13:49, Michael Balzer <dexter at expeedo.de
> <mailto:dexter at expeedo.de>> wrote:
> Steve,
> use the vehicle_obdii module to get into OBD polling on the OVMS.
> You begin by defining the poll requests to be sent in at least one
> array of type OvmsVehicle::poll_pid_t. A request consists of
> * the transmission address (CAN ID), this may be a specific
> address or the broadcast address 0x7df
> * the expected response address (CAN ID), or 0 in case of a
> broadcast
> * the type of the request; OBD also calls this "mode", e.g.
> 0x22, there are preprocessor definitions for all supported
> types, e.g. 0x22 = VEHICLE_POLL_TYPE_OBDIIEXTENDED
> * optionally the PID to access (depending on the request type,
> may be none / 8 bit / 16 bit)
> * the poll interval; this may be specified for up to 4 vehicle
> states (normally used to switch intervals according to the
> car's operation mode, like sleeping / driving / charging)
> * optionally the CAN bus to use for the request
> For your example of polling the SOC, this would be:
> * transmission address:0x6F1
> * response address: 0x607
> * type: 0x22 or VEHICLE_POLL_TYPE_OBDIIEXTENDED
> * PID: 0xDDBC
> * poll interval: as you like, e.g. { 0, 10, 60 } -- assuming for
> sleeping, driving, charging
> End the array with an all zero entry. The poller will
> automatically loop over the list.
> Call OvmsVehicle::PollSetPidList() to set the array to be used,
> call OvmsVehicle::PollSetState() to set the vehicle state
> (defining the poll intervals).
> Override OvmsVehicle::IncomingPollReply() with your result
> processing. The method will be called by the framework for each
> response part. The framework also supplies polling state variables
> you can use (see vehicle.h). A typical pattern to collect multiple
> frames is:
> void OvmsVehicleRenaultTwizy::IncomingPollReply(
> canbus* bus, uint16_t type, uint16_t pid, uint8_t* data, uint8_t
> length, uint16_t mlremain)
> string& rxbuf = twizy_obd_rxbuf;
> // init / fill rx buffer:
> if (m_poll_ml_frame == 0) {
> rxbuf.clear();
> rxbuf.reserve(length + mlremain);
> rxbuf.append((char*)data, length);
> if (mlremain)
> return;
> // complete:
> switch (pid) {
> This pattern collects the payload in a string buffer, regardless
> of the length.
> Decoding and converting the payload to metrics is up to you, but
> normally is simple.
> For your example:
> // complete:
> switch (pid) {
> case 0xDDBC: {
> unsigned int soc_raw = ((unsigned int)rxbuf[0] << 8) |
> (unsigned int)rxbuf[1];
> float soc = soc_raw / 10.0f;
> StdMetrics.ms_v_bat_soc->SetValue(soc);
> break;
> On your question:
>> 2020-11-15 10:34:36.474 <-- 607␣F1␣03␣7F␣22␣78␣⏎ //
>> this is some unrelated packet?
> Actually it's related, it's the first reply of the device and
> means "I'm busy, but stand by, results will come soon". The poller
> handles these.
> If you want to follow the poller operation, activate debug logging
> for the vehicle module: log level debug vehicle
> There's more on the poller, but that should get you going.
> Am 12.12.20 um 10:19 schrieb Steve Davies:
>> Hi,
>> Can I ask someone to help me get started with pulling data off
>> the OBD-2 on the I3.
>> I have info on what works via an LM327 and I know the pids, but
>> it would help me for some pointers as to how to do it on the OVMS.
>> You know - the goal to get the first one working.
>> Here's an example definition - the SOC of the main battery. This
>> is extracted from decompiling a definition file for
>> ediasbas/ediasblib:
>> (The "_EN" text is translated using Google cloud translate so the
>> German is the original)
>> The "job" is defined like so:
>> "SERVICE" : "22",
>> "ID" : "0xDDBC",
>> "DIV" : "-",
>> "INFO" : "aktueller Anzeige Soc",
>> "RES_TABELLE" : "RES_0xDDBC_D",
>> "ARG_TABELLE" : "-",
>> "EINHEIT" : "-",
>> "DATENTYP" : "-",
>> "ARG" : "ANZEIGE_SOC",
>> "LABEL" : "-",
>> "ADD" : "-",
>> "MUL" : "-",
>> "INFO_EN" : "current advertisement Soc",
>> "L/H" : "-",
>> "RESULTNAME" : "-",
>> "NAME" : "-",
>> "SG_ADR" : "-"
>> The "results" are defined like so:
>> "RES_0XDDBC_D" : [
>> "DIV" : "10.0",
>> "DATENTYP" : "unsigned int",
>> "EINHEIT" : "%",
>> "MASKE" : "-",
>> "RESULTNAME" : "STAT_ANZEIGE_SOC_WERT",
>> "L/H" : "high",
>> "MUL" : "1.0",
>> "ADD" : "0.0",
>> "NAME" : "-"
>> "NAME" : "-",
>> "ADD" : "0.0",
>> "MUL" : "1.0",
>> "L/H" : "high",
>> "RESULTNAME" : "STAT_MAXIMALE_ANZEIGE_SOC_WERT",
>> "INFO" : "obere Grenze des Anzeige Soc",
>> "MASKE" : "-",
>> "INFO_EN" : "upper limit of the display Soc",
>> "EINHEIT" : "%",
>> "DIV" : "10.0"
>> "RESULTNAME" : "STAT_MINIMALE_ANZEIGE_SOC_WERT",
>> "L/H" : "high",
>> "MUL" : "1.0",
>> "NAME" : "-",
>> "ADD" : "0.0",
>> "DIV" : "10.0",
>> "INFO_EN" : "lower limit of the display Soc",
>> "EINHEIT" : "%",
>> "INFO" : "untere Grenze des Anzeige Soc",
>> "MASKE" : "-"
>> I read it that three unsigned ints (16 bits each) are returned.
>> Each is divided by 10 to return a "%".
>> I traced an app that can retrieves this parameter using an LM327
>> based OBD2 interface.
>> That app initialises the LM327 like so:
>> 2020-11-15 10:34:28.831 --> ATD Return all settings to default
>> 2020-11-15 10:34:28.849 --> ATE0 Disable command echo
>> 2020-11-15 10:34:28.861 --> ATH1 Show CAN message headers
>> 2020-11-15 10:34:28.875 --> ATAL Allow long messages
>> 2020-11-15 10:34:28.887 --> ATPBE101 Set programmable param 0x2c
>> to 0xE1, 0x2d to 0x01
>> - 2c=0xE1:
>> - 11 bit IDs
>> - variable data-length code
>> - 11 or 29 bit received IDs
>> - use data format ISO 15765-4 (CAN)
>> - 2d=0x01
>> - Use rate divisor of 1
>> 2020-11-15 10:34:28.901 --> ATSPB Use protocol USER1 CAN (as set
>> above I think)
>> 2020-11-15 10:34:28.949 --> ATBI Bypass initialisation -
>> apparently a bad idea... ?
>> 2020-11-15 10:34:28.964 --> ATSH6F1 Set header bytes to 0x6F1 (
>> 0x06F1 ? )
>> 2020-11-15 10:34:28.978 --> ATAT0 Disable adaptive timing - wait
>> up to ATSF time
>> 2020-11-15 10:34:28.992 --> ATSTFF Maximum wait
>> Then, when it fetches this PID it does the following:
>> 2020-11-15 10:34:35.101 --> ATCRA607⏎ //
>> Listen for 0x607
>> 2020-11-15 10:34:35.114 <-- OK⏎⏎>
>> 2020-11-15 10:34:35.115 --> ATCEA07⏎ // "extended
>> address" 0x07 [matches 607?]
>> 2020-11-15 10:34:35.127 <-- OK⏎⏎>
>> 2020-11-15 10:34:35.129 --> ATFCSH6F1⏎ // Flow
>> control header
>> 2020-11-15 10:34:35.141 <-- OK⏎⏎>
>> 2020-11-15 10:34:35.143 --> ATFCSD07300800⏎ // Flow
>> control data
>> 2020-11-15 10:34:35.156 <-- OK⏎⏎>
>> 2020-11-15 10:34:35.157 --> ATFCSM1⏎ // Flow control mode
>> 2020-11-15 10:34:35.170 <-- OK⏎⏎>
>> 2020-11-15 10:34:36.367 --> 22␣DD␣BC⏎ // asking for
>> "extended" PID 0xDDBC
>> 2020-11-15 10:34:36.539 <-- 607␣F1␣10␣09␣62␣DD␣BC␣02␣4C␣⏎ //
>> reply --> 0x24C = 588 = 58.8 SOC
>> 607␣F1␣21␣03␣A6␣00␣69␣FF␣FF␣⏎ // 0x03A6 = = 93.4%,
>> 0x0069 = 10.5%
>> 2020-11-15 10:34:37.598 <-- ⏎>
>> Remember the LM327 takes the sent bytes and wraps with into a
>> full CAN message - though I'm not sure exactly how that comes out
>> - I presume that "extended address" goes in somewhere.
>> --> 22 DD BC is the PID
>> <-- 2 part reply. First has the SOC. Second has 0x03A6 (934)
>> and 0x0069 (105)
>> First int is 588 or 58.8% which is the physical SOC of the battery.
>> 934 is 93.4 which is the physical SOC level which the car
>> displays as "100%" (i3 keeps some headroom "reserved").
>> 105 is 10.5 which is the physical SOC level that the car displays
>> as 0%.
>> I'd appreciate some help to give me a head-start to be able to
>> retrieve this attribute on the OVMS box.
>> Thanks,
>> Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201212/8cb90e11/attachment-0001.htm>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20201212/8cb90e11/attachment-0001.sig>
