[Ovmsdev] Configuring notifations
Chris van der Meijden
chris at arachnon.de
Mon Aug 31 21:19:59 HKT 2020
Found the subtypes in the vehicle.cpp.
Thanks a lot!
Chris
Am Montag, den 31.08.2020, 14:19 +0200 schrieb Michael Balzer:
> The logic is currently defined as…
> std::string filter = MyConfig.GetParamValue("notify",
> subtype);
> if (!filter.empty() && filter.find(m_caller) ==
> string::npos)
> return false;
> So you need to define the config param to be non-empty, but
> without
> containing "ovmsv2".
> The parameter is also named after the notification subtype. See
> the
> Notify…() calls for the subtypes currently in use.
> So to disable all notifications for charge start, state and stop
> events, do:
> config set notify charge.started -
> config set notify charge.stopped -
> config set notify charge.done -
> config set notify heating.started -
> …that should cover all of these notifications.
> I think it would be good to extend the config logic, to allow
> excluding single channel tags. For example, "*,-ovmsv2"
> could mean "all but ovmsv2". I'll do that after office.
> Am 31.08.20 um 12:25 schrieb Chris van
> der Meijden:
> > The vehicle.charge notifications are default on.
> > They are not shown when you check with
> > config list notify
> > I can add with
> > config set notify vehicle.charge ovmsv2
> > and then list again.
> > I also can remove with
> > config rm notify vehicle.charge
> > Is there a way known to remove the default vehicle.charge
> > notifications?
> > Thanx
> > Chris
> > Am Montag, den 31.08.2020, 16:11 +0800 schrieb Mark
> > Webb-Johnson:
> > > From what I can see, the filtering is by
> > > subtype, on caller.
> > > In the case of ovms_server_v2, I see:
> > > MyOvmsServerV2Reader =
> > > MyNotify.RegisterReader("ovmsv2",
> > > COMMAND_RESULT_NORMAL,
> > > std::bind(OvmsServerV2ReaderCallback, _1, _2),
> > > true,
> > > std::bind(OvmsServerV2ReaderFilterCallback, _1,
> > > _2));
> > > Which seems to enable filtering, and uses ‘ovmsv2’ as
> > > the
> > > caller.
> > > Then we have:
> > > bool
> > > OvmsNotifyCallbackEntry::Accepts(OvmsNotifyType*
> > > type, const char* subtype, size_t size)
> > > // Check size
> > > if (size > m_verbosity)
> > > return false;
> > > // Check filter by config:
> > > if (m_configfiltered)
> > > MyConfig.GetParamValue("notify", subtype);
> > > filter.find(m_caller) == string::npos)
> > > return false;
> > > // Check filter by callback:
> > > if (m_filtercallback)
> > > if (m_filtercallback(type, subtype) == false)
> > > return false;
> > > return true;
> > > So I’m guessing ‘config set notify vehicle.charge
> > > ovmsv2’? Or is that filter out, so needs to list the
> > > notifications that it will accept? First time I’ve
> > > noticed
> > > this, and can’t even remember us having this
> > > facility.
> > > Regards, Mark.
> > > > On 30 Aug 2020, at 8:43 PM, Chris van der
> > > > Meijden <chris at arachnon.de>
> > > > wrote:
> > > > I just finished the implementation of
> > > > the "charging detection" for the komfort-
> > > > can VW
> > > > e-Up. Works like charm :-) (Msg ID 0x61C,
> > > > d2. No
> > > > Ampere and Volt yet).
> > > > Because I have email notifications
> > > > activated I now receive mails when I start
> > > > or end
> > > > charging. For me it is enough to see the
> > > > charging in
> > > > the app and I would like to configure the
> > > > notifications to not sent me messages on
> > > > vehicle.charge.start, vehicle.charge.state and
> > > > vehicle.charge.stop
> > > > I found this thread from 2018:
> > > > http://lists.openvehicles.com/pipermail/ovms
> > > > dev/2018-May/004980.html
> > > > and I found the "Notification filtering"
> > > > and "Event filtering" under Config ->
> > > > Notifications, but I did not see a way to
> > > > disable an
> > > > specific notification. Or just do not
> > > > understand
> > > > how. Am I overlooking something?
> > > > Thanx
> > > > Chris
> > > > _______________________________________________
> > > > OvmsDev mailing list
> > > > OvmsDev at lists.openvehicles.com
> > > > http://lists.openvehicles.com/mailman/listinfo/
> > > > ovmsdev
> > > http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200831/78bc38d9/attachment.htm>
