[Ovmsdev] Configuring notifations
Mon Aug 31 20:19:56 HKT 2020
The logic is currently defined as…
std::string filter = MyConfig.GetParamValue("notify", subtype);
if (!filter.empty() && filter.find(m_caller) == string::npos)
return false;
So you need to define the config param to be non-empty, but without
containing "ovmsv2".
The parameter is also named after the notification subtype. See the
Notify…() calls for the subtypes currently in use.
So to disable all notifications for charge start, state and stop events, do:
config set notify charge.started -
config set notify charge.stopped -
config set notify charge.done -
config set notify heating.started -
…that should cover all of these notifications.
I think it would be good to extend the config logic, to allow excluding
single channel tags. For example, "*,-ovmsv2" could mean "all but
ovmsv2". I'll do that after office.
Am 31.08.20 um 12:25 schrieb Chris van der Meijden:
> The vehicle.charge notifications are default on.
> They are not shown when you check with
> config list notify
> I can add with
> config set notify vehicle.charge ovmsv2
> and then list again.
> I also can remove with
> config rm notify vehicle.charge
> Is there a way known to remove the default vehicle.charge notifications?
> Thanx
> Chris
> Am Montag, den 31.08.2020, 16:11 +0800 schrieb Mark Webb-Johnson:
>> From what I can see, the filtering is by subtype, on caller.
>> In the case of ovms_server_v2, I see:
>> MyOvmsServerV2Reader = MyNotify.RegisterReader("ovmsv2",
>> COMMAND_RESULT_NORMAL, std::bind(OvmsServerV2ReaderCallback, _1, _2),
>> true,
>> std::bind(OvmsServerV2ReaderFilterCallback, _1, _2));
>> Which seems to enable filtering, and uses ‘ovmsv2’ as the caller.
>> Then we have:
>> bool OvmsNotifyCallbackEntry::Accepts(OvmsNotifyType* type, const
>> char* subtype, size_t size)
>> // Check size
>> if (size > m_verbosity)
>> return false;
>> // Check filter by config:
>> if (m_configfiltered)
>> return false;
>> // Check filter by callback:
>> if (m_filtercallback)
>> if (m_filtercallback(type, subtype) == false)
>> return false;
>> return true;
>> So I’m guessing ‘config set notify vehicle.charge ovmsv2’? Or is that
>> filter out, so needs to list the notifications that it will accept?
>> First time I’ve noticed this, and can’t even remember us having this
>> facility.
>>> On 30 Aug 2020, at 8:43 PM, Chris van der Meijden <chris at arachnon.de
>>> <mailto:chris at arachnon.de>> wrote:
>>> I just finished the implementation of the "charging detection" for
>>> the komfort-can VW e-Up. Works like charm :-) (Msg ID 0x61C, d2. No
>>> Ampere and Volt yet).
>>> Because I have email notifications activated I now receive mails
>>> when I start or end charging. For me it is enough to see the
>>> charging in the app and I would like to configure the notifications
>>> to not sent me messages on vehicle.charge.start,
>>> vehicle.charge.state and vehicle.charge.stop
>>> I found this thread from 2018:
>>> http://lists.openvehicles.com/pipermail/ovmsdev/2018-May/004980.html
>>> and I found the "Notification filtering" and "Event filtering" under
>>> Config -> Notifications, but I did not see a way to disable an
>>> specific notification. Or just do not understand how. Am I
>>> overlooking something?
>>> Thanx
>>> Chris
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200831/9ed099b7/attachment.htm>
