[Ovmsdev] lost important event => aborting
Mon Aug 31 16:24:25 HKT 2020
I've made a stupid mistake leading to events at least not being
forwarded correctly to Duktape, fix is pushed.
PS: Mark, your split of the scripting module may not allow easy merging
of my two commits. They are simple, but I can do the merge if you push
them into a branch.
Am 29.08.20 um 15:54 schrieb Michael Balzer:
> I think I've found & fixed this, maybe also the events starvation issue.
> See
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/418#issuecomment-683286134
> and
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/6b709a0cb399d1a7c3866f68d7f9dbf92f9246c8
> Please test.
> Am 29.08.20 um 10:34 schrieb Michael Balzer:
>> I've just found another clue to the events task starvations:
>> TL;DR: the events task can be blocked by running lower priority tasks as
>> well, not just higher priority tasks.
>> So raising the events task priority cannot be the solution.
>> Am 26.08.20 um 20:28 schrieb Michael Balzer:
>>> Am 26.08.20 um 06:17 schrieb Mark Webb-Johnson:
>>>> It seems to be a web socket (web ui?) connection went away, a logging
>>>> message was produced, and that overflowed the queue. Perhaps the user
>>>> is just logging too much? Can you log at debug level to web uI (or
>>>> does it cause the problem I mentioned earlier about debug logging the
>>>> debug logs)? Any ideas?
>>> I haven't been able to get a correlation to any specific configuration
>>> or system situation yet on these event queue overflows.
>>> The event queue has room for 40 entries by default, so the system
>>> normally has been in an overload situation (starved event task) for at
>>> least 30-40 seconds when the abort is triggered.
>>>> Event: ticker.1 at EventScript 0 secs
>>> …tells the events task wasn't completely stuck before the abort, just
>>> didn't get a lot of CPU share. That's why I thought raising the task
>>> priority could have an effect.
>>> I totally need user data on this, as the crash doesn't happen at all on
>>> my module. So it's also possible the issue is caused by a vehicle module
>>> bug, or by the poller receive bug we discovered a few days ago:
>>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/405#issuecomment-674499551
>>> This is solved now by the merge of the fast polling branch, which
>>> includes the fixes for this. So we may see already an improvement with
>>> the next build.
>>> But there are at least three more bugs/shortcomings in the current
>>> poller which can potentially also cause this issue (and others) by high
>>> vehicle task load / wrong memory allocations / out of bounds accesses.
>>> Which is why I'm currently working on a rewrite of the receiver.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200831/e600687e/attachment.htm>
