[Ovmsdev] lost important event => aborting
Sat Aug 29 21:54:40 HKT 2020
I think I've found & fixed this, maybe also the events starvation issue.
See
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/418#issuecomment-683286134<https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/418>
and
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/6b709a0cb399d1a7c3866f68d7f9dbf92f9246c8
Please test.
Am 29.08.20 um 10:34 schrieb Michael Balzer:
> I've just found another clue to the events task starvations:
> TL;DR: the events task can be blocked by running lower priority tasks as
> well, not just higher priority tasks.
> So raising the events task priority cannot be the solution.
> Am 26.08.20 um 20:28 schrieb Michael Balzer:
>> Am 26.08.20 um 06:17 schrieb Mark Webb-Johnson:
>>> It seems to be a web socket (web ui?) connection went away, a logging
>>> message was produced, and that overflowed the queue. Perhaps the user
>>> is just logging too much? Can you log at debug level to web uI (or
>>> does it cause the problem I mentioned earlier about debug logging the
>>> debug logs)? Any ideas?
>> I haven't been able to get a correlation to any specific configuration
>> or system situation yet on these event queue overflows.
>> The event queue has room for 40 entries by default, so the system
>> normally has been in an overload situation (starved event task) for at
>> least 30-40 seconds when the abort is triggered.
>>> Event: ticker.1 at EventScript 0 secs
>> …tells the events task wasn't completely stuck before the abort, just
>> didn't get a lot of CPU share. That's why I thought raising the task
>> priority could have an effect.
>> I totally need user data on this, as the crash doesn't happen at all on
>> my module. So it's also possible the issue is caused by a vehicle module
>> bug, or by the poller receive bug we discovered a few days ago:
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/405#issuecomment-674499551
>> This is solved now by the merge of the fast polling branch, which
>> includes the fixes for this. So we may see already an improvement with
>> the next build.
>> But there are at least three more bugs/shortcomings in the current
>> poller which can potentially also cause this issue (and others) by high
>> vehicle task load / wrong memory allocations / out of bounds accesses.
>> Which is why I'm currently working on a rewrite of the receiver.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200829/3060c1ab/attachment.htm>
