[Ovmsdev] Override WebUI Dashboard
Soko ovms at soko.cc
Sat Aug 22 16:05:52 HKT 2020
Hello,
Thanks for the info. I've played with the GetDashboardConfig() methods
and hook posibilities already.
I want to use the Dashboard of the OVMS via the smartphone (placed in
the holder of the e-Up) which is connected to the OVMS APs WiFi. Imho
there is no point in showing data I have already in the cars dashboard
(i.e. km/h) in the OVMS dashbard. I want to display mainly values there
I don't see in the car yet...
So thats why I don't want to hook or frankly even fill the values of the
standard dashboard.
I will give MyWebServer.RegisterPage() a try.
thx
Soko
On 21.08.2020 20:25, Michael Balzer wrote:
> Soko,
> user plugins currently cannot override system pages. That's by design
> for security and system stability.
> Compiled modules OTOH can override all system page handlers simply by
> calling MyWebServer.RegisterPage() on the URI to replace, passing their
> own handler. The default behaviour of the API call is to replace an
> existing handler.
> Before replacing the dashboard completely, consider customizing and/or
> extending it.
> The dashboard gauges can be customized by overriding the
> OvmsVehicle::GetDashboardConfig() method. See
> OvmsVehicleRenaultTwizy::GetDashboardConfig() for an example.
> Hook extensions (inline page callbacks) can be installed by users and by
> compiled modules. See:
> https://docs.openvehicles.com/en/latest/components/ovms_webserver/docs/hooks.html
> …and the webserver's RegisterCallback() method.
> The dashboard provides the "body.pre" hook for extensions. See
> OvmsVehicleRenaultTwizy::WebExtDashboard() for a native code example
> adding a drive mode profile switcher to the dashboard. This example user
> plugin adds tuning sliders to the dashboard:
> https://docs.openvehicles.com/en/latest/components/ovms_webserver/docs/plugin-twizy/dashboard-tuneslider.html
> Am 21.08.20 um 16:50 schrieb Soko:
>> Hey guys,
>> I've found the possibility of creating own pages via Web Plugins which
>> is really great.
>> https://docs.openvehicles.com/en/latest/components/ovms_webserver/docs/dashboard.html
>> talks of installing your own dashboard by using exactly this feature.
>> Is it possible though to replace the default Dashboard link with my
>> own page? So the default dashboard is gone and it uses my own page?
>> thx
>> Soko
