[Ovmsdev] Refactoring MODEM/SIMCOM for v3.3
Craig Leres leres at xse.com
Fri Aug 21 10:23:27 HKT 2020
On 2020-08-20 18:26, Mark Webb-Johnson wrote:
> Did you ever get that SIM7600 working? It certainly requires some
> changes to the CMUX arrangements, as there is no CMUXSRVPORT command
> implemented.
Nope. I spent some time looking at the documentation and concluded it
was a larger project than I wanted to engage at the time.
> We’re also seeing high peak power usage on that module. 450ma to 600ma
> at 5V. Can’t run it off most laptop/computer USB 2 ports (the power draw
> brings voltage down to 4.5V or so, and brownouts occur). It seems to run
> ok on USB 3. We’re probably going to have to redesign the modem board
> power supply to get this working reliably. On the positive side,
> reception does seem better than the 5360 - I can even get a single in
> the cellular blackhole that is my home office.
Interesting. The 12V wart I'm powering my dev ovms module off of is only
rated for 500 mA. But I did little more than enter some AT commands and
verify that it could register on the cell network.
Better reception sounds good; my motivation in going this direction is
that at a minimum it would give us a better selection of cell towers to
talk to.
		Craig
