[Ovmsdev] Frequent Crashes
Derek Caudwell
d.caudwell at gmail.com
Tue Aug 18 10:04:57 HKT 2020
With DukTape disabled and Mcp2515 overflow logging turned off the module
has run and been stable for 5 days or so however I had it crash today with
the following log entry.
2020-08-18 13:16:55 NZST I (12067) ovms-server-v3: Tx notify
ovms/nismo/notify/data/debug.crash/1/0=*-OVM-DebugCrash,0,2592000,3.2.014-45-g390b4759-dirty/ota_0/edge
(build idf v3.3.2-881-g22d636b7b-dirty Aug 13 2020
19:05:42),13,Crash,12,12,1,0,abort(),0,,0x4008e96b 0x4008ec05 0x400e6aec
0x40084122 ,6,Task watchdog,ticker.1,esp32wifi,0,IDLE1
It appears the issue remains (note this is with OVMS Events set to priority
19), however the likelihood of it causing the module to crash is reduced.
Let me know if you have other suggestions to debug it, otherwise I will
re-enable DukTape and see if anything changes.
Cheers
Derek
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200818/4658364f/attachment.htm>
