[Ovmsdev] V2H mode
Derek Caudwell d.caudwell at gmail.com
Thu Aug 13 17:28:07 HKT 2020
Hi all,
How about the following framework:
V2G framework - used to set mode, set current/charge limits and query
status  with commands such as,
V2G mode - used to set mode either V2G, G2V, REM (default - mode remotely
set by charger/V2G/V2H unit)
V2G limit - used to set limits such as charge/discharge current limit and
SOC min/max limits
V2G status - used to report mode, limits set and power/current flow
V2G start - used to start powerflow in a given mode
V2G stop - used to stop powerflow
The basic wrappers could be defined in vehicle.h/cpp and the feature
confirmed as supported in the specific vehicle and coded to implement the
specific command features.
Views?
Cheers Derek
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200813/3b710286/attachment.htm>
