[Ovmsdev] Time for 3.2.014?
Tue Aug 4 16:53:18 HKT 2020
Released to EAP on ovms.dexters-web.de as well.
Am 04.08.20 um 10:37 schrieb Mark Webb-Johnson:
> This has been built and released to EAP:
> 2020-08-04 MWJ 3.2.014 OTA release
> - Renault Twizy: support VirtualBMS & eDriver BMS (3 cell
> temperature sensors)
> - Wifi: scanning apclient mode, network selection dialog in wizard
> & wifi config,
> scan support in all modes, fixed network selection by signal
> strength
> (possibly also fixes issue #387)
> New/updated commands:
> wifi scan -- can now be issued in any mode
> wifi scan -j -- output scan result as JSON object (for
> web UI)
> wifi reconnect -- request a client reconnect cycle
> wifi mode apclient -- now accepts empty stassid & optional
> stabssid
> - #377 Make some metrics (e.g. v.b.soc) persistent across warm reboots
> This includes crashes and firmware updates
> - Tesla Roadster support for Baolong TPMS
> - Tesla Model S support for Baolong TPMS
> - General stability improvements related to watchdog and task timeouts
> For full changelog, see:
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/changes.txt
> I’ll target a full MAIN release at the coming weekend.
> Thanks in particular to Michael for the wifi improvements in this
> release. I’ve found them incredibly useful and it is great to be able
> to do access point and a scanning wifi client at the same time.
>> On 4 Aug 2020, at 10:04 AM, Mark Webb-Johnson <mark at webb-johnson.net
>> <mailto:mark at webb-johnson.net>> wrote:
>> I would like to build a 3.2.014 for EAP (and after a few days -> MAIN).
>> Any objections? Anything last minute to go in?
>> Once that is out, I can start to bring in my plugin framework
>> extensions (and also changes to command/script for command extensions
>> in javascript) - I think we can call that 3.3.001.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200804/5f9ea849/attachment.htm>
