[Ovmsdev] Frequent Crashes
Sat Aug 15 17:16:04 HKT 2020
Derek,
Am 13.08.20 um 10:50 schrieb Derek Caudwell:
> With the script and store/events folder removed the unit was still
> crashing, I changed the task priority to 19 and it was still crashing,
> however it may have reduced the frequency of crashes. Given their
> intermittent frequency it is hard to say.
Did you see the same kind of crash signatures with the events task
running at priority 19?
Can you send me your debugcrash logs?
Thanks,
> I have now turned off DukTape in the build config and will see how
> that goes. If it is stable then it will confirm there is some issue
> with the interaction of DukTape with another part of the system.
> I will report back in a couple of days.
> Cheers
> Derek
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200815/01f431e3/attachment.html>
