[Ovmsdev] Script engine not working?
Soko
ovms at soko.cc
Sat Aug 1 16:51:50 HKT 2020
Hey guys,
I've tried to use the script engine and created some files. But when I
run the files nothing happens. No output at all. Here is my webc onsole
trys:
OVMS# vfs ls /store
[DIR] 01-Jan-1980 00:00 ovms_config/
[DIR] 01-Aug-2020 10:12 scripts/
OVMS# vfs ls /store/scripts
35 01-Aug-2020 10:27 vfstest.bat
35 01-Aug-2020 10:29 vfstest.js
35 01-Aug-2020 10:31 vfstest.cm
35 01-Aug-2020 10:31 vfstest.cmd
35 01-Aug-2020 10:33 vfstest.py
OVMS# vfs head /store/scripts/vfstest
vfs ls /store
OVMS# script run /store/scripts/vfstest
I would expect the output of the two first commands after running the
script! What am I doing wrong here? I've also tried some different file
extensions as you can see. I've also had a look into the source (static
void script_ovms(...)) to find the special file extension that is
needed. But apparently everything besides .js is handled as command script.
Soko
PS: I've created the files via the web editor. Do they need any special
termination character after each line?
