[Ovmsdev] Vehicle Idle Notification
Sat Aug 1 02:32:30 HKT 2020
Derek,
awake = switched on (manually), on = ignited.
Charging is charging (not necessarily awake while charging, but possible).
Am 31.07.20 um 13:11 schrieb Derek Caudwell:
> Hi all,
> In Vehicle.cpp the NotifyVehicleIdling() routine is essentially called
> when StdMetrics.ms_v_env_awake is true and the idle ticker has
> expired. My understanding from the standard metrics documentation is
> that the awake metric is to indicate activity on the can bus eg when
> charging or prior to the vehicle being turned on. Hence I was only
> expecting an idle notification if the vehicle has been
> accidentally left in the on state indicated
> by StandardMetrics.ms_v_env_on. Or have I misunderstood how the two
> metrics and idle function are intended to work or mean?
> Cheers Derek
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200731/6e51bb3b/attachment.html>
