[Ovmsdev] 3.2.011 BUG for MIEV based cars
Tamás Kovács
kommykt at gmail.com
Sun Apr 26 02:24:14 HKT 2020
Thanks the log, now i modified the AC charge detection code.
If you want to try add the following to config / firmware / flash from web
: kommykt-nas.ddns.net:22289/ovms3.bin
This is my NAS, the internet speed is not very high.
Should I rewrite the old RR display during quick charging?
Michael Eric Menk <mikeemenk at gmail.com> ezt írta (időpont: 2020. ápr. 25.,
Szo, 15:37):
> On 25.04.2020 14:21, Tamás Kovács wrote:
> > Sorry the good command is
> > can log start vfs /sd/file.crtd 286
> Still not correct command, but I used help.
> http://vedlegg.uib.no/?id=a56c8b273221fc3ddca3755ccdc84488
> 2min charge at 6A 230V IT
> Both connect and disconnect is in the dump.
Üdvözlettel:
Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200425/24d77c94/attachment.htm>
