[Ovmsdev] 3.2.011 BUG for MIEV based cars
Michael Eric Menk mikeemenk at gmail.com
Sat Apr 25 18:55:33 HKT 2020
I've tried the command you sendt.
OVMS# can log crtd /sd/file.crtd 286
Unrecognised command
Ths option crtd seams not to exist.
OVMS# can log ?
list                 Logging list
start                CAN logging start framework
status               Logging status
stop                 Stop logging
OVMS# can log start ?
monitor              CAN logging to MONITOR
tcpclient            CAN logging as TCP client
tcpserver            CAN logging as TCP server
vfs                  CAN logging to VFS
And yes, I do get the data from the BMS.
> Ideal range calculation is = cell_number * 3.7 * bat_cac * bat_soc /
> 16100.  So my full charge ideal range is ~75km.
No matter what method used, it should never set the RR from the can bus
while fast-charing. In my opinion, better the value set to ''  or '-'
than 255.
On 21.04.2020 20:00, Tamás Kovács wrote:
> Please create a log file while you charging with 230V (1-2 minutes
> enough), start logging before connect charger and send it to me.
>   * |can log crtd /sd/file.crtd 286|
>   * …record…
>   * |can log stop|
>   * http://ovmsname.local/file.crtd
> The Ideal range is based on 16.1kWh/100km consumption and the battery
> health (this updated during charge, quick and normal charge). My car
> is 2012 Peugoet iOn, with SOH 78%, and my RR at 100% is 113km, the old
> code calc the RR during quickcharge with last rr 20 and range 8km if
> soc < 20 this is too optimistic i think.
> In your car the bms cell monitor working?
> Michael Eric Menk <mikeemenk at gmail.com <mailto:mikeemenk at gmail.com>>
> ezt írta (időpont: 2020. ápr. 21., K, 12:58):
>     On 18.04.2020 05:41, Tamás Kovács wrote:
>>     Please send the following command output during charge. AC
>>     (Type1) or DC(CHAdeMO charge the problem?
>>     _
>>     _
>>     _me li v.c._
>     I hava a 80 cell 2015 Citroën C-Zero. VIN: VF71NZKYZFU900455 230V
>     6A charge after 1.1kWh charged.
>>     v.c.charging                             no
>>     v.c.climit                               0A
>>     v.c.current                              0A
>>     v.c.duration.full
>>     v.c.duration.range
>>     v.c.duration.soc
>>     v.c.kwh                                  0kWh
>>     v.c.limit.range
>>     v.c.limit.soc
>>     v.c.mode                                 None
>>     v.c.pilot                                no
>>     v.c.state                                stopped
>>     v.c.substate                             interrupted
>>     v.c.temp                                 25°C
>>     v.c.time                                 0Sec
>>     v.c.timermode
>>     v.c.timerstart
>>     v.c.type                                 None
>>     v.c.voltage                              0V
>     Fast charging (start) CC mode
>>     v.c.charging                             yes
>>     v.c.climit                               124A
>>     v.c.current                              124.6A
>>     v.c.duration.full
>>     v.c.duration.range
>>     v.c.duration.soc
>>     v.c.kwh                                  0kWh
>>     v.c.limit.range
>>     v.c.limit.soc
>>     v.c.mode                                 CHAdeMO
>>     v.c.pilot                                yes
>>     v.c.state                                charging
>>     v.c.substate                             onrequest
>>     v.c.temp                                 19°C
>>     v.c.time                                 20Sec
>>     v.c.timermode
>>     v.c.timerstart
>>     v.c.type                                 Quickcharge
>>     v.c.voltage                              320.7V
>     Fast charg CV mode
>>     v.c.charging                             yes
>>     v.c.climit                               38A
>>     v.c.current                              38.88A
>>     v.c.duration.full
>>     v.c.duration.range
>>     v.c.duration.soc
>>     v.c.kwh                                  0kWh
>>     v.c.limit.range
>>     v.c.limit.soc
>>     v.c.mode                                 CHAdeMO
>>     v.c.pilot                                yes
>>     v.c.state                                charging
>>     v.c.temp                                 21°C
>>     v.c.time                                 817Sec
>>     v.c.timermode
>>     v.c.timerstart
>>     v.c.voltage                              328.1V
>     As you can se, the v.c.kwh do not increase, but
>     xmi.e.trip.park.energy.used while charging. An other bug, RR
>     (Range Remaining) is set to 255 on the CAN bus while fast
>     charging, this is now set to 255 out to the user. [1] The code
>     earlier saved the last known value of RR and of SOC, and
>     calculated the RR base on SOC while fastcharging. I find it weird
>     that CC-max goes down during the CV stage of the charging. I
>     started a change of code. The idea was to warn user about reduced
>     speed due to temperature. I stopped when I saw the code change.
>     Coldest cell under 1°C => Max 25A (C/2) Coldest cell under 11°C =>
>     Max 50A (C) Warmest cell over 46°C => Max 85A (looks like its more
>     dynamic, no cell goes above 47) Warmest cell over 30°C => Max 100A
>     (2C) Optimal (11-29°C) => Max 125A (2.5C) BTW: If someone know how
>     to start the heater + fanspeed low when Type-1 charging (the
>     DC-bus is energized when type-1 charging), that would bee neat.
>     [1] https://tjinfo.uib.no/Vedlegg?id=e9d1c4031a9f03d196f07e6be82bbe2f
>     _______________________________________________
>     OvmsDev mailing list
>     OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>     http://lists.openvehicles.com/mailman/listinfo/ovmsdev
> Üdvözlettel:
> Kovács Tamás
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200425/6e262623/attachment.htm>
