[Ovmsdev] Flash memory and developement setup
Wed Apr 8 14:01:55 HKT 2020
Eddy,
note that Fabrizio works on porting the OVMS to ESP-IDF 4:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/263#issuecomment-606132473
Maybe you can join forces?
Am 08.04.20 um 04:05 schrieb Mark Webb-Johnson:
>> Am I correct to assume that the 16Mb of memory is on the module now?
> The ESP32 chip uses an external flash chip. The WROOM/WROVER modules include a flash chip in the modules.
> In the very early days of development prototypes for OVMS v3, we used an external 16MB flash chip (as only 4MB WROOM modules were available at the time).
> For production, we switched to 16MB WROVER modules, so don’t require any external flash chip any more.
>> How are the core developers dealing with this slowness?
> I don’t find it slow at all (but I use MAC and LINUX for development). Most of the time, it is an incremental build (only building changes code, and then a
> linking step) - it normally takes longer to flash the chip than build the code. I timed a full ‘make clean; make -j 4’ to see what it is for me:
> $ time make -j 4
> real2m53.557s
> user5m55.978s
> sys1m40.391s
> Just under 3 minutes real time. Perhaps you can check in windows to see how much worse it is?
>> Is it at all possible, if i could force platformio to use the correct the idf-esp libraries, to compile the OVMS code in a more recent environment that uses
>> cmake and ninja?
> I haven’t tried it myself. We do have some make scripts in various components that may rely on the existing build system. Things like the versioning.
> OVMS was written when ESP-IDF was quite new, and unpolished. At some point, we will most likely migrate to a newer build system, as ESP-IDF matures.
>> On 8 Apr 2020, at 8:37 AM, Eddy Vromen <eddy_vromen at hotmail.com <mailto:eddy_vromen at hotmail.com>> wrote:
>> HI All,
>> I have a question about the flash memory of the ESP32.
>> I read that the ESP32 uses 16Mb of external flash memory and in the schematics on page 27 there is a flash memory chip. However, in the latest v3.2
>> schematics there is no external flash chip.
>> How does this impact the e-fuse settings?
>> Another question that came up while setting up a development environment:
>> The version of esp-idf thats used by the OVSM project uses the Mingw32 environment. Based on my limited exposure to using this environment, its very slow
>> compared to compiling esp-idf code under e.g. platformio under VSCode.
>> cmake and ninja?
>> Thanks,
>> Eddy
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20200408/f0cf8c9f/attachment.htm>
