[Ovmsdev] Roadster: Some alerts not showing up
Chip Cangialose
chip at cangmag.com
Thu Oct 31 16:49:44 HKT 2019
Watching this thread with some interest as I, like Greg, would like to see the “Debug” alerts over OVMS. I would note that if the goal is to have OVMS show what the VDS shows, if you have the Roadster set to “Show Debug”, then OVMS will not show what VDS shows. Is it possible to track the status of “Debug reporting to VDS” in the car, and have the OVMS server relay accordingly?
Thanks, and apologies for jumping in.
Chip
Sent from my tablet
On Thu, Oct 31, 2019 at 1:30 AM +0100, "Mark Webb-Johnson" <mark at webb-johnson.net> wrote:
The server doesn’t have any per-vehicle configuration (other than authentication), so not sure how this could be easily done server side.
A kludge might be to pickup the notification event in a javascript on the module, and then raise a new different textual event for specific IDs - but not sure if the vehicle module javascript framework gets enough about the raised notification in order to do that.
An alternate kludge would be to manually list vehicle IDs to be exempted from the DMC policy in the ovms_server.conf file, and have code to check that in ovms_server.pl.
But, that said, I’m not really sure why we would want this. Our goal has always been to mirror what it says on the little VDS in the car, and that doesn’t show these debug-only alerts. The solution we have is not perfect, but it does avoid the worst of them. I have received so many support questions and concerns from roadster users of OVMS asking about these over the years - Tesla is aware that they false positive so labelled them as debug-only, so why would we want to bombard the user with these alerts every time he drives/charges the car?
On 31 Oct 2019, at 7:39 AM, Greg D. <gregd2350 at gmail.com> wrote:
Bummer.
Can we make this configurable? While I understand that debug
messages aren't intended to be seen by the user, in the 10 years
since these cars launched we have come to know a lot more about some
of the, um, "quirks" in their design. These alerts can be
important!
Greg
Mark Webb-Johnson wrote:
Greg,
Yes, this change to the server code:
* bcc02c27 Ignore DMC push alert messages
That won’t notify debug-only messages, but will still
continue to notify the user-visible ones (to better mimick the
behaviour in the car itself). Including, for the roadster:
1144=DMC: Powertrain Problem Service Required
1146=DMC: Motor Fan Problem
On 31 Oct 2019, at 7:01 AM, Greg D. <gregd2350 at gmail.com>
wrote:
Hi folks (Mark, probably),
Interesting... My Tesla Roadster has been having
trouble with its PEM
fan, causing a bunch of 1146 Alerts to be generated
while driving and/or
charging. I've been monitoring the situation via
OVMSv3.
The alerts suddenly stopped a bit over a week ago.
Other events
continue to be received (charge start, stop, key in /
door open, etc.),
but not the 1146's. I do a monthly download of the car
logs, and to my
surprise (and disappointment), the 1146s are still
happening.
Was there a change to the plumbing somewhere such that
these diagnostic
alerts (perhaps versus user-visible events) are now
being filtered out?
Thanks,
Greg
OvmsDev mailing list
OvmsDev at lists.openvehicles.com
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191031/e61903e5/attachment.htm>
