[Ovmsdev] WifiConsole V1.0
Thu Oct 10 09:35:37 HKT 2019
I think in v2 that could have been the case (as we didn’t have any standardised functions for things like climate control). But in the v3 architecture we now have these and the vehicle modules should support the standard functions to the best of their abilities.
If we still need mappings like Homelink 1 -> Climate On, then that should be done either by scripts or by some centralised mapping framework.
> On 9 Oct 2019, at 2:19 PM, Jaunius Kapkan <jaunius at gmx.com> wrote:
> I am making a couple of plugins (initially for leaf) and the JS functions are great for that. However I assume the functions are not unifed accross different vehicles. For example for leaf to turn on pre-heat you need to issue Homelink 1 instead of ClimateControl. What would be the best way to change this? Or is this something that need to be changed on the lower level?
> Greetings,
> Jaunius
>> Sent: Tuesday, October 08, 2019 at 9:05 AM
>> From: "Michael Balzer" <dexter at expeedo.de>
>> To: ovmsdev at lists.openvehicles.com
>> Subject: Re: [Ovmsdev] WifiConsole V1.0
>> Mark,
>> yes, the OLEDs are perfect for these things, bright enough for daylight use with very little energy usage.
>> Thanks for the link to that combined ESP32 module, that's a real beauty, even includes a LiPo supply / charger. I need to check that one out.
>> Regarding our Javascript support, I already had stunned some users with the foglight plugin, they thought stuff like this would need builtin
>> support. That brought me back to my point about how little users know about our capabilities, so I added an explanation to our docs:
>> http://docs.openvehicles.com/en/latest/components/ovms_script/docs/foglight.html
>> But we really need something like an OVMS cheat sheet as an overview of what is possible.
>> Am 08.10.19 um 05:40 schrieb Mark Webb-Johnson:
>>> Michael,
>>> I really like those little OLED SSD1306 based displays. I use them on my esphome+hassio projects like this little water tank level (using an
>>> ESP32, a BME280 pressure/humidity/temperature sensor, waterproof ultrasonic distance sensor, and SSID1306 OLED yellow/blue display):
>>> Adding a display to a project makes it so much more useful and easy to diagnose problems.
>>> AliExpress has them very cheap:
>>> * https://www.aliexpress.com/item/32844104782.html
>>> US$2 for the 0.96” yellow/blue 128x32
>>> US$3 for the 1.3” white 128x64
>>> There is also a 4MB ESP32 with a 0.96” OLED display on-board:
>>> * https://www.aliexpress.com/item/32822105291.html
>>> US$9 plus shipping
>>> Glad that you are finding a use for our JavaScript support. I really think that has so many possibilities.
>>> Regards, Mark
>>>> On 6 Oct 2019, at 10:43 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>> FYI: I've just implemented an OVMS v3 style replacement for the SimpleConsole:
>>>> https://github.com/dexterbg/WifiConsole
>>>> V3 makes it pretty easy now to add stuff like this. It's using a script plugin to provide custom functions via the web API.
>>>> Regards,
>>>> Michael
