[Ovmsdev] WifiConsole V1.0
    Wed Oct  9 19:08:12 HKT 2019
Jaunius,
I don't have a Leaf, but from the code I assume the ClimateControl command should work just as well on the Leaf:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/vehicle_nissanleaf/src/vehicle_nissanleaf.cpp#L1324
Am 09.10.19 um 08:19 schrieb Jaunius Kapkan:
> I am making a couple of plugins (initially for leaf) and the JS functions are great for that. However I assume the functions are not unifed accross different vehicles. For example for leaf to turn on pre-heat you need to issue Homelink 1 instead of ClimateControl. What would be the best way to change this? Or is this something that need to be changed on the lower level?
> Greetings,
> Jaunius
