[Ovmsdev] Added Pushover and SSL client support
Fri Oct 18 21:25:32 HKT 2019
The Pushover support isn't enabled now in our default builds, because…
a) MBEDTLS_PSK_MODES defaults to "no"
b) MG_ENABLE_SSL also defaults to "no"
c) OVMS_COMP_PUSHOVER would default to "yes" but depends on a) + b)
Should we set these to "yes" for the edge release now?
Am 29.07.19 um 21:07 schrieb Marko Juhanne:
> Hello all,
> I've been wanting to have a bit more configurable notification system on my mobile phone compared to the OVMS mobile app (quiet hours, different message
> priority levels, override quiet hours with emergency priority, custom sounds, persistent notifications demanding acknowledgment etc). I already use Pushover
> as notification platform for my home automation system and it has worked nicely for these two past years so I decided to port Pushover client to OVMS as well.
> For those who don't know, Pushover is a notification platform that has apps for iOS and Android. They also have a desktop (actually web) application as well.
> You create an account and then register your application. There's a 5 USD per platform one-time fee, which I find quite reasonable. Message limit is 7500
> messages / month / application. So if you have multiple cars, you could register them as individual applications. I'm not affiliated with the company, just
> a happy customer.
> There are now commits for Pushover support on my fork (https://github.com/mjuhanne/Open-Vehicle-Monitoring-System-3). It's up to date with the main branch,
> and has the SWCAN commits as well. I would appreciate if others could test it before making a pull request, since there are now quite many changes. I didn't
> want to add another http client, so I used Mongoose. But then after enabling SSL support using mbedssl I found out that there's this client space "struct
> mg_connect_opts" that will be too small (and causes crash) if MG_ENABLE_SSL is not enabled also in every component that uses Mongoose.
> To configure Pushover, there's a new Config/Notifications page on OVMS. You can filter which notifications and events will be relayed and select their
> priority levels accordingly. I thought about using web config pluging, but maybe we could integrate this page to configure notifications for OVMS mobile apps
> as well?
> Best regards,
> Marko Juhanne
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191018/70bf5feb/attachment.html>
