[Ovmsdev] SWCAN and enhanced Ampera/Volt support
    Fri Oct 18 20:48:55 HKT 2019
Everyone,
I've merged Marko's first set of enhancements, which covered some more themes (see pull request #259 for details).
Please test & report.
Am 18.07.19 um 10:14 schrieb Marko Juhanne:
> Hi all,
> I've been tinkering with OVMS and Opel Ampera these few past months, and the I've made some progress with the SWCAN support.
> As you know, the SN65 transceiver cannot do High-Voltage Wake Up, so many of the nice-to-have polling and remote controlling functions are not available on
> those cars that rely on it, such as Volt/Ampera. So I've created an add-on SWCAN board that attaches to the internal OVMS extension header. The board uses
> TH8056 transceiver, which is specifically designed for SWCAN bus. As for the controller, same MCP2515 is used as in OVMS.
> Here's the link to the boards GitHub page: https://github.com/mjuhanne/OVMS-SWCAN
> For the firmware patches, here's my OVMS branch: https://github.com/mjuhanne/Open-Vehicle-Monitoring-System-3
> There are a lot of changes, especially MCP2515 code add-ons and refactoring, of which some are specific to the new swcan-bus, but some could be beneficial
> otherwise as well. Then there's the support for the new board and TH8056. On the other hand, if a car can be woken up without HV WakeUp, the board is not
> really needed and the SN65 can be used with 33.3 kbps speed to communicate on SWCAN bus.
> Since ESP32 supports only 3 hardware CS on one SPI bus and all the CS lines are now already used, there's also patches for software CS (that's what the
> additional MCP2515 is using). With my OBD cable I wire SWCAN to use CAN2 lines and put the 2nd MCP2515 on OVMS to sleep, but there's no reason why all the 4
> CAN controllers couldn't work independently at the same time (untested at this time).
> There's also patches to the Ampera/Volt module code base to include SWCAN support, add handling of several new CAN messages (still work in progress, more to
> come!), as well as VoltStar-like capabilities (locking/unlocking doors, remote preheat) similar to Brian Batista's MyVolStar app/OBDLink MX-combo. Sadly, I
> haven't been able to get the VoltStar-specific functionality to work on my 2014 Ampera, but other non-Voltstar SWCAN messages do work (waking up the car,
> controlling windows etc.). This is is similar to other reports of MyVolStar on 2014 Volt/Ampera, so maybe something has changed in the ECU behaviour between
> MY13 and MY14.
> It would be really nice to get other OVMS developers with SWCAN/GMLAN enabled cars to test these. SWCAN specific patches can be tested also without the board,
> but naturally the HV Wakeup functionality is not available.  Let me know if you're interested so I can send a PCB or two for testing (I have bunch of leftovers).
> Best regards,
> Marko
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20191018/29bc10b7/attachment.html>
